Old 06-22-2002, 12:21 PM   #1
too many
too many's Avatar
Anyone ever done an AC retro?
I am looking at a 67 pickup without AC. I was wondering if anyone has had experience installing an original indash AC unit from a donor truck? I have a 72 junk cab with air. I know Id have to change the interior dash and probably "graft " part of the firewall and change heater box, etc.
I also am thinking of updating the fuse panel from the 72 by grafting that part of the f.wall while Im cutting.
I do plan on hooking the AC up. Any suggestions, or know of a GOOD 67 cab with AC?
THANKS!
too many is offline   Reply With Quote
Old 06-22-2002, 01:51 PM   #2
DINS 1
DINS 1's Avatar
I have not done one yet but will be removeing the factory front and rear a/c out of a burb and installing it in another
Wade
"DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project
2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's
79 RS Camaro
DINS 1 is offline   Reply With Quote
Old 06-22-2002, 08:23 PM   #3
Low69CST
I'm in the process of doing this right now. If you do a search for posts I've started then you'll find alot of pics I've taken from doing this swap.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
