Old 05-27-2006, 02:26 AM   #1
javanaut
Diesel was run in a '66 Chevy C10...what now?
I'm about to start the process of fixing up a 1966 Chevy C10 truck that had a tank of diesel filled in it. It died in a ball of smoke and was parked 10 years ago when it was parked and has sat since then. The engine block is coated in black sludge. I'm curious to know what the possibility is for rebuilding the 283 V8 that's in it. Does this sort of thing cause damage that requires an engine rebuild or can this be cleaned out without open heart surgery?
javanaut is offline   Reply With Quote
Old 05-27-2006, 09:13 AM   #2
Baer
Baer's Avatar
Re: Diesel was run in a '66 Chevy C10...what now?
We had one on the farm where I worked the guy put diesel in the gastank, We took the tank off drained and washed out with gas, blowed the gas line out with air, pulled the carb and dumped the diesel out, pulled the spark plugs, put gas in each cylinder, cranked it over blowing gas and diesel out of the cylinders, it took a while, but it finally started running good, I would definately put new plugs in it. As for sitting for 10 years, that shouldn't affect it as diesel has an oil base. Someone else may have more knowledge of one sitting 10 years, but the one we done was like a week later when we cleaned it up.
Baer is offline   Reply With Quote
Old 05-27-2006, 10:21 AM   #3
Chevrolet4x4s
Chevrolet4x4s's Avatar
Clean it up....change the oil.....dump the tank....new plugs....fire it up
Shane
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 05-27-2006, 11:07 AM   #4
javanaut
Cool! I'm having it transported this week, and I'll start working on it next weekend. It sounds like a relatively straight-forward job. Thanks!
Old 06-07-2006, 08:33 PM   #5
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
sitting for so long the carb may also need a rebuild. mine was a mess with only old gas sitting for a couple years.
Hey sombodys gotta do it!
jgrh64 is offline   Reply With Quote
Old 06-09-2006, 04:48 PM   #6
javanaut
I'll spray some carb cleaner in it and see how it goes. I'm planning on replacing the carb and intake soon, anyways. I don't have much use for a 2bbl carb
Old 06-25-2006, 09:03 AM   #7
624whldr
drive it not trailer it
i had that happen to in a 66 4x4 burb and drove it about 10 miles smelled like a kerosene heater then smoked real bad bad cracked one of the heads ./good luck make sure you drain it all out
624whldr is offline   Reply With Quote
