12-19-2006, 12:47 AM | #1 |
Tools for installing bolt-in notch?
Ok I ordered my notch and shock relocators from CPP today. I've never done this before but i get the general consensus it isnt too bad...
Ok I have access to an angle grinder with a cut off wheel and a jigsaw for the cutting part. The thing I'm unsure about is how to get off those huge blasted rivets? Do I drill them out with my hand drill (sounds horrible!) or can I grind them down with a grinder or what? I don't have an air chisel or anything fun like that so I'm kinda limited... Any tips? Thanks, Nate |
12-19-2006, 02:04 AM | #2 |
Re: Tools for installing bolt-in notch?
Yep.... you can grind the heads off & punch the remainder through the hole (not as easy as it sounds though).
Do yourself a favor & stop off @ your local 'rent-all' center & get a small 110 air-compressor & an air chisel. That will definitely make the job much easier & shouldn't break the bank if you use your time wisely.
12-19-2006, 10:39 AM | #3 |
Active Member
I used drill bits, started small (3/16) then went to a bit the size of the hole for rivet.
If the rivets didn't just fall off (hole drilled off center) I just used a cold chissle to finish. Rivets seem to be soft (to drill). just use cutting oil on drill bits to save them. Use a center punch to mark the center of the rivet. Good luck Jac |
12-19-2006, 11:27 AM | #4 | |
This will make the job about 4 hours shorter.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-19-2006, 12:53 PM | #5 |
ok, but now you need to explain to me what exactly I would do with the air chisel? I've never even touched one! What is the proper technique?
thanks, Nate |
12-19-2006, 01:26 PM | #6 |
The air chisel is basically a fast repetitive air hammer that uses different tips for different functions. Use a sharp, angled, 'chisel' tip to knock off the rivets head & then swap out to a 'punch' tip to finish poking the remainder of the rivet carcass through the hole.
An alternative method to speed the chiseling off of the rivet heads is to first cut them in a criss-cross pattern down to the frame material w/a cut-off wheel. It makes quick work of knocking them off the rest of the way.
12-19-2006, 01:45 PM | #7 |
Señor Member
Use power tools where possible. If you do this manually, you will want to pack a lunch
12-19-2006, 06:19 PM | #8 | |
Outlandish Trends - FL
-Bret 67 short-fleet sold! |
12-20-2006, 12:04 AM | #9 |
well i found a friend with an air chisel now i need to find one with a portable air compressor...and the parts came today! those notches look beefy!
Nate |
12-20-2006, 12:42 AM | #10 |
Check your local rent-all if you can't get one from a friend . . .....
12-20-2006, 12:59 AM | #11 |
if all else fails... torch em.
-1947 3100 -1968 C10 -1970 K20 |
12-20-2006, 02:01 AM | #12 | |
A guy with a truck
Good luck -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-20-2006, 08:50 AM | #13 |
I don't know if this will help or not!http://67-72chevytrucks.com/vboard/s...d.php?t=195566
Kevin LFD Inc. |
12-20-2006, 09:41 AM | #14 |
Active Member
My truck was not that hard-I did about 40 rivets in less the 30 min with a drill and 2 bit sizes. If you use an air chissel make sure you get a big compressor as they use a lot of air. My truck is down to the frame so I am sure that helped. I have a chissel but for me the drill was way faster.
Jack |
