Old 10-08-2014, 12:10 PM   #1
Hardrockz28
Front grill 1966 install help needed
Does any one have the steps on installing the front grill?
Doing the mock up on front end all head light brackets installed to front bulk head. Now looks like I have to remove and attach to grill then install to bulk head. Photos would be great as I'm thinking I'm missing parts
Got the truck in boxes when I bought the truck and was told all is there but know better now as have been having to find little parts on the board
Frank
Hardrockz28 is offline   Reply With Quote
Old 10-08-2014, 12:17 PM   #2
ol_skool_chevy
ol_skool_chevy's Avatar
Re: Front grill 1966 install help needed
There is only 6 bolts holding the grill in place....its not hard they should all line up if your using stock parts.
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 10-08-2014, 09:08 PM   #3
VictoriaHardware
VictoriaHardware's Avatar
I think you are saying that you have only the grill brackets mounted and now you are attempting to mount the grill to the brackets- correct?
If that is the case, then yes you need to remove them and mount the grill to the brackets. Originally it was done with rivets, but machine screws and nuts will work too. Then attach the whole grill assembly to the bulkhead.
VictoriaHardware is offline   Reply With Quote
Old 10-08-2014, 09:23 PM   #4
VictoriaHardware
Right side- front and rear pics. Empty grill shell and with bracket assembled.
Old 10-09-2014, 11:54 AM   #5
ol_skool_chevy
Opps....sorry i misunderstood.
he's right to use machine screws or what i did was go to harbor freight and bought a rivet gun. I also riveted in my headlight adjustment screws
Mark with Chalk
Cut with a torch
Old 10-10-2014, 07:40 AM   #6
66BigBackWindow
When I did mine I used machine screws as well with a little permatex thread locker. That way if I disassemble again for any reason I am not trying to cut rivets and damaging the soft aluminum.
66BigBackWindow is offline   Reply With Quote
Old 10-10-2014, 09:13 AM   #7
Hardrockz28
Thanks everyone, after another trip to the hardware store I got the grill and front end all mocked up.
