Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 10-25-2023, 07:31 PM   #1
aotte1
Gmc 351e big block v6
GMC 1966 351E big block V6 out of a suburban that had 4 speed. Dressed pretty much as it was removed. Ran good when removed, suburban was customized reason for removal. It has PS installed and dealer installed AC parts in box (date coded 12/65). Price $500, needs to go, local pick up. Trying to sell whole to some one who needs, other wise will strip for parts. More photos if needed. AC parts are in a box not installed, under dash type unit by Eaton.
Still editing
aotte1 is offline   Reply With Quote
Old 10-25-2023, 08:56 PM   #2
1960chevypanel
Re: Gmc 351e big block v6
Interested in PS including pulleys if you part out
1960chevypanel is offline   Reply With Quote
Old 11-04-2023, 10:23 AM   #3
55-72 GM trucks
Junior Member
So, These are my questions
1) is the Y pipe in tact or cut?
2) is the air cleaner not with it?
3) is the 4 speed still attached and does it come with it or available separately?
55-72 GM trucks is offline   Reply With Quote
Old 11-27-2023, 05:24 PM   #4
AngryPirate
AngryPirate's Avatar
The gentleman that owns or runs https://www.olsonsgaskets.com/ (pretty much the only place I can find oil pan gaskets for the GMC v6) needs a donor engine to reverse engineer the rear seal gasket.
I'm guessing this engine is likely the same internally as the 305 (for his purposes) with the exception of the pistons/cylinders?
You may see him pop into the classifieds.
He saved my bacon because he has gaskets for our trucks.
AngryPirate is offline   Reply With Quote
Old 11-27-2023, 06:44 PM   #5
1960chevypanel
Where is he located?
Old 11-27-2023, 06:50 PM   #6
AngryPirate
looking on the website it seems it might be Port Orchard, WA , which I guess isn't close to where the engine might be.
Old 11-30-2023, 10:53 AM   #7
55-72 GM trucks
Junior Member
probably gonna have to do a better job of answering questions if Aotte wants to sell anything on here
Old 12-09-2023, 09:36 AM   #8
55-72 GM trucks
Junior Member
PM sent Aotte - call me
Old 12-09-2023, 10:05 PM   #9
Backpayne
I wish I could find one of these near SWMO.
Backpayne is offline   Reply With Quote
Old 12-10-2023, 11:40 PM   #10
aotte1
No y pipe, only manifold;
Air cleaner came w/engine, not sure origional.
No transmission.
I have lots going on currently, so may may be slow to respond, thanks for understanding.
