11-01-2009, 10:01 PM | #1 |
People know me
fish eyes
Got a hood for my 67 out of the junk yard, It looks to be all white from the
factory with orange around the raised portion of the hood, The flat portion on the top is all white. I was sanding down rock chips and oxidation good enough to lay down some primer. When I was sanding through the orange i was getting alot of pits in the paint, looked like swiss cheese. I cleaned everything up good, wiped down with acetone and sprayed primer. I got fish eyes all over where the prange used to be. What gives and how can I get my primer to lay down right? It was fine everywhere else on the hood.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
11-01-2009, 11:55 PM | #2 |
Re: fish eyes
dumb question but did you sand all the pits out? The orange was probably sprayed with fish eye eliminator in it. Ironic, that would be whats CAUSING them now. basically what the eliminator does it INTRODUCE silicone into the paint. mixed in it "eliminates" them. small quanities on the suface "causes" them. The acetone can be doing it too. Sand the primer flat, clean with wax and grease remover and then let it sit before you spray primer. Spray a light coat on first and you will see right off it they are coming back. If not, continue on.
11-03-2009, 06:56 PM | #3 |
Official Site Guitar Shredder
Re: fish eyes
Agreed..........
