12-01-2021, 08:06 PM | #1 |
65 with cross member swap what perch?
I promise i have searched for over two hours and can’t find an answer. Ok I have a 65 frame swapped 86 cross member. I’m installing a 5.3 what mounting holes do I use? Front or rear?
12-01-2021, 09:01 PM | #2 |
Re: 65 with cross member swap what perch?
Holes to mount the crossmember, or holes to mount the motor?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
12-01-2021, 09:33 PM | #3 |
Holes to mount the motor
12-01-2021, 10:31 PM | #4 |
I did a 65 with Ls1, I made my own mount and put the engine where it fit best….
12-01-2021, 11:11 PM | #5 |
I made my own as well, and positioned the motor so I could still remove the heads even with head studs installed. I used an existing hole in the crossmember.
Where you put them, is really going to depend on where you place your motor in the firewall and chassis. Don't be afraid of drilling holes.
12-02-2021, 12:02 PM | #6 |
With my 65 Gen IV 5.3 swap with square body crossmember I used P.O.L. frame perches. I remember they didn't fit perfectly and I had to oblong some holes and leave the bolts loose to help line them up to get the motor mount bolts in. Then I tightened the bolts. I used some engine adapter plates purchased from ebay - Blackheart racing? I think. They had four different positions and I used the 3rd position forward to get the engine forward enough to just clear the passenger head from the firewall. I removed the rear most coil mount stud that was going to hit the firewall.
