Old 07-04-2010, 06:19 PM   #1
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
Bad engine Knock
well my buddys 91 Mitsu Galant GSX 2.0 16V has a very bad knock to it but we arnt couite sure what it is. we think it might be rod bearing but the knock my self and my buddy have heard (both mechanics) havent been this bad its very very loud but it dose not get louder when the engine is reved.
this happen all of a sudden accelerating out of a turn the engine only has 108740 miles on it allways been serviced very very well taken off car.
here a vid of it
the head has been machined and had a valve job done to it because the Timing belt was broken when he bought it. this is not the original head.
the compression is now 174PSI and was original 137PSI
the Belt driven Blancer Shaft has been disconected ( dose not hurt the engine) as these has a tendensi to throw bearings and sies up
the engine ran very very well.
The thing we noticed also. we put a few gauges in it like oil pressure, Vacum and AMP meter. we hooked everything correct but the oil pressure gauge read like 87 PSI at idle and it is supose to be 21 PSI at idle (800 RPM)
we thought it maby just was because it was some crappy gauges as they where cheap. well after the engine started knocking the oil pressure gauge read normal 21 PSI at idle witc is kinda strange right?
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 07-04-2010, 11:24 PM   #2
shortbed70
shortbed70's Avatar
Re: Bad engine Knock
That sounds like some messed up injector pulses on the video.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 07-05-2010, 10:46 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Even though I have no idea what the noise is, I usually isolate weird noises to a particular location by using a 3 foot section of garden hose as a "stethoscope".
Place one end close close to the engine and move it around until the noise you are looking for is the loudest. Works for me every time. Good luck...
68gmsee is offline   Reply With Quote
