Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-28-2011, 02:37 PM   #1
smallblockchev
e85
I am planning a new engine build around e85. I want to put together a 406 with higher compression but wondering how much power my 3/8 fuel line will support if I step up to e85 from gas. I have heard the 3/8 will support 550-600 hp gas but I am not sure on e85 because it takes so much more fuel.
I am in the very early planning stages so if you have some ideas fire away.
This will be going in a 71 c10, 29 inch rear tire, 3.73 gears, and is completely a weekend cruise truck. I do plan on hitting the strip this summer though.
So far was thinking scat cast crank, forged scat rods, forged speed pro domed pistons, some Ik 200 or track 1 heads, and topped with an rpm air gap. I haven't thought about a cam yet.
2007 Chevy 2500HD all stock
1985 Chevy Blazer- sold
1971 Chevy c10- The Mistress
2014 Ford Interceptor SUV
smallblockchev is offline   Reply With Quote
Old 01-28-2011, 02:43 PM   #2
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Re: e85
Ditch the speed pro pistons, they have horrible quality control issues any more. I wouldnt sell a set of speed pros to my worst enemy.
ProStreet68SB is offline   Reply With Quote
Old 01-28-2011, 03:26 PM   #3
smallblockchev
Re: e85
For a little more I was also looking at SRP's.
Old 01-28-2011, 03:30 PM   #4
ProStreet68SB
Re: e85
SRPs are an awesome choice.
Old 01-28-2011, 03:36 PM   #5
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: e85
With E85 you need to be able to support about 30% more fuel volume for a given power level than you do with gasoline.....so to support 500hp on e85 you'd need a fuel system that would support 650ish on gas, plus the components need to be alcohol resistant.
I would stay away from domed pistons if you can.....a flat top piston and a smaller chamber will promote better flame travel.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 02-04-2011, 02:01 PM   #6
smallblockchev
Re: e85
I am going to build the short block now and hopefully finish the rest this summer. How does this sound so far:
400 block .030 over
Scat 9000 cast crank
Scat forged I beam rods
SRP -4cc dome forged pistons ( I realize flat tops are more efficent but running E85 I think I will gain more from the higher compression without having to mill a new set of heads)
Comp Cams XE274H
Brodix IK 200's
Single plane manifold
Holley 750 set up for E85
This is my start. Hoping for 475-500hp and 500-525 tq. It will be going in my 71 c10, TH350 and 12 bolt rear. Probably will be a 28in tire.
