guys i really need your help if you know how to help me and my dad please reply
okay today i go out side and notice i the battery is dead on my dads 1970 chevy lwb 1/2 ton because my mom left the lights on
Re: guys i really need your help if you know how to help me and my dad please reply
Where's it look like its coming from, Front, back, pan, dipstick. Need more info. I'm assuming its a 4x4
Never Ending Projects
You likely have a seal that is bad and when it sits the converter is draining back, which will raise the fluid level higher then the seal that is leaking. It then drains thru that seal until the fluid level is below that point.
As for which seal, it can be any number of ones but a really common one is the o-ring on the dipstick where it comes into the trans case. It can be a real output seal, selector shaft seal, pan gasket, etc. You really need to find out where the fluid is dripping/leaking from to know what to fix. Also, you are checking the fluid while it is running, after cycling thru all the gear selections and putting it back into Park, correct? Ideally you want to do this when it is hot as well. You can overfill the trans which can also cause it to leak. Good luck.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
it is dripping from ?????? down to the tranny crossmember then onto the floor so anywhere above the crossmember....yes it is a 4wd 1/2 ton chevy stock height
If it's dripping onto the transmission/tcase crossmember it might be the rear seal or even the T-case. You're going to have to get under the truck with a flashlight and find where the leak is originating from - maybe even remove the trans tunnel/hump if it helps.
If you can't tell, clean everything up real well then let it sit and see where the new drips come from. |
thank you!
Some TH350s have a vent hole in the end of the trans yoke, and I guess an internal seal. This tends to leak after the truck has been parked for several days and is a pain to track down. Something else to look for.
#8 | |
I like More's Law 'If more is better, then too much is just right.' http://s1238.photobucket.com/albums/...20chevy%20k10/ 1971 Chevelle - sbc 350 TH350 1961 K10 - sbc 400 4 spd M/T short stepside Last edited by kingburnett; 02-07-2011 at 10:25 PM. |
thanks guys this is all good info and each of these will be tried we are gonna take it down to see what is wrong and if its easy we will fix it if not then we will jave it fixed
Junk Yartist
It's not leaking, it's just marking it's territory.
Or, like I tell the operators (drivers) at work. If you let it leak long enough, it will eventually stop. Sounds like the problem can be fixed by simply installing a 700r-4 Seriously though, you may want to wear some grungy clothes, bring a stiffer bristle brush like a dish washing brush and some dawn, take it to the car wash, and clean the padookie out of the tranny and t-case. Now that all the grime is gone, you can watch a clean surface to see where the leak is coming from. Seals for the TH350 are cheap. It could be the pan seal, it could be the governor cover seal... both are easy to change. If you have a chrome pan, than that is whats leaking. Chrome makes shiny leaks. I have some really good tips for leak-proofing a tranny pan if you need them.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
its not the pan he has a beautiful aluminum pan he said it has a ''pin'' that is sticking out and it looks like leaking on the upper right above the t case so he says what is it? he also says there is a line coming off of it?
Junk Yartist
yeah if its an aluminum pan than its probably not leaking. I may be wrong, but you may be seeing the vacuum modulator seal leaking.
thanks jeremy its just wierd how it all of the sudden happened! to bad my 67 wasnt running it could take the place of my dads truck! with the help of your parts i will be alot closer!
tighten pan bolts while youre under there
#15 |
#16 |
aluminum pan on a turbo 350? very few 40 plus year old transmisions have pan bolts that are all tight,had a friends 60 chevy convertable in garage last spring that he hadnt driven in 2 years because somebody told him oil leak was being caused by bad rear rope seal on pan/crank.
turns out all the oil pan bolts were loose,i tightened everything up and he hasnt had a leak since. sometimes simple repairs are the right answer ![]() Last edited by plummen; 02-08-2011 at 03:57 PM. |
#17 | |
You are right - start with the easy/cheap repairs and move on. Like I said though, check the torque on them rather than just tightening the bolts. Regardless, it doesn't sound like his leak is from the pan. |
#18 |
well it was at the shop almost the hole day and now my dad is on his way to go get it back it was the tranny/t-case gasket ,it was 150 i think ,its prob. only 20 for the seal and the 130 is in labor ! it must be hard having to take off all of this stuff and then put it back together again.......
#19 |
$130 sounds fair to me considering you have to pull both drive lines, shift linkage, maybe move the exhaust, possibly cross member, horse the transfer out and back in. They weigh about 300# and do not have a good balance point so its a real wrestling match.
#20 |
exactly what i was thinking! they said they may have to take the tranny out....we are gonna get it toda turns out they werent done yesterday...
