Old 04-19-2011, 09:39 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
No heat after LS swap.
I installed a 01 6.0 dbc in my 72 GMC last year near the end of summer, and didn't get much heat at all from the cab heater. Put it away for the winter around October 1 last year. So, I get it out last weekend and it's 40* here in Indiana and I'm not getting much heat out of the vents. Fan blows good but it's mostly 60-70* air. Temp gauge always runs at 180*. I thought maybe swap my 2 heater hoses around on water pump and see what happens. I installed new water pump and t-stat when LS was installed last year. Truck has a/c too but not hooked up yet. What to do?
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 04-20-2011, 11:16 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: No heat after LS swap.
Clogged heater core?
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-21-2011, 07:12 AM   #3
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
That's going to be what I check next. How hard is that to change? Go at it from the inside or outside?
Old 04-21-2011, 11:01 PM   #4
usmcchevy
usmcchevy's Avatar
Factory AC will come out from the inside. Good luck.
Build thread
LSx Swap FAQ index
Old 04-22-2011, 04:33 AM   #5
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
yes sir, thats what I need.
Old 04-22-2011, 07:06 AM   #6
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
hook a garden hose to your heater core and see how it flows?? it might be as simple as it being air bound.....if you think its a cloggged core try unhooking the hoses from the block and draining the water out keep one hose up high and fill it with CLR and let it sit for awhile then hook the hoses up backwards and flush it out then try that......but my real guess is air bound
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 04-22-2011, 12:46 PM   #7
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Ya, I hear some gurgling down there by heater core sometimes. Thanks guys.
Old 05-02-2011, 08:48 PM   #8
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Clogged heater core it was. Blew air through it with air nozzle, then jet stream on garden hose. Works great now. Thanks.
Old 05-03-2011, 09:28 AM   #9
Clyde65
Clyde65's Avatar
Love it! I know I tend to panic when something like that happens, glad it worked out for you.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
