Old 11-09-2011, 06:31 AM   #1
bikernut
bikernut's Avatar
No Start
My 2003 GMC 3500 4x4, 6.0 engine with auto trans won't start. I shut it off and went to start it later to move it and it just does nothing with the starter. I have all my lights, gauges inside as well as lights outside. The dump body works fine. I did check the batteries and found one defective so I went and purchased a new one but that wasn't the answer.
I checked to make sure the neutral safety switch hadn't loosened up and moved but it still won't start in any gear selection and putting the vehicle in reverse the back up lights & back up alarm work when in the R position on the selector. I have gone under and taken a hammer and rapped the starter to see if that worked with some one turning the key but again no start. The solenoid doesn't even click. I tried to purchase a solenoid but you have to purchase the whole stater assembly, and they cost $412 at dealership but my cost with discount is $303 still big bucks.
I looked in the electrical fuses to see if there was a relay or something that was bad but didn't find anything but maybe you fine folks have had this happen to some of you and can point me in the right direction before I spend $ for a new stater.
thanks for any help you can send my way.
2020 GMC Acadia Denali (Maroon)
2003 GMC 3500 4X4 Dually Dump (Red)
2007 KZ 41KG Toy Hauler (White with stripes)
2015 Harley FLHTCUTG Trike ( Maroon)
1995 Harley FLT (2 tone Red)
1992 Chevy S-10 4x4 Blazer (Dark Red)
bikernut is offline   Reply With Quote
Old 11-09-2011, 11:20 AM   #2
clinebarger
Re: No Start
Remove the starter relay from the underhood fuse block, jump pin 30 & pin 87 (diagram). If the starter works check the 10A IGN E fuse & the 10A CRANK fuse.
clinebarger is offline   Reply With Quote
Old 11-26-2011, 02:44 PM   #3
bikernut
bikernut's Avatar
Re: No Start
UPDATE
It seems that the solenoid was broke all to dickens, replaced starter and it now starts.
