12-21-2011, 10:14 PM | #1 |
factory tach???
factory tach??? well almost, started out doing the camaro tach fuel gauge thing to my electronic speedo, didn't like the look of it, so bought a little tach from princess auto, with a shift light, took it all apart, made it fit behind the original gas gauge, installed the smaller maro fuel gauge, got a local decal place to make me a new front for it, and then installed factory needles to finish it off, also installed a factory clock. Not as easy as it sounds, had to remake the hole original housing, and printed board, but it turned out pretty good, and now I can use the 4cyl mode
12-22-2011, 01:34 PM | #2 |
Re: factory tach???
This looks incredible. Take any more pics during the assembly?
12-22-2011, 05:05 PM | #3 |
Re: factory tach???
so it is possible to make the 4 cylinder mode work?
12-23-2011, 11:45 AM | #4 |
Re: factory tach???
Ls engines use 4 cylinder tach out put, so by using an aftermarket tach its possible to use 4,6,or 8 cylinder mode.
Tach looks great! How did you re do the printed circuit? Any pics of the back? Posted via Mobile Device
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
12-23-2011, 02:44 PM | #5 |
Re: factory tach???
oh i see
12-25-2011, 11:22 PM | #6 |
Re: factory tach???
sorry no pics, it was a real b!tch, had to cut apart another housing to make it deeper under the tach for clearance, could have just cut a hole in it, but had more time then that so... lol... then had to cut the printed circuit, moved a bunch of wires around, by re soldering, and extending them because of clearance issues, the gauge was from an electronic speedo truck, and getting put into a 76, so the plug in wires had to be moved around on the truck side to match up with the newer style gauge, also had to run a wire for the oil pressure gauge
12-30-2011, 12:48 AM | #7 |
Just a Member
Re: factory tach???
DUDE!!! This is freaking sick!!! SKILLS!!!!!!!!
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
05-29-2012, 12:19 PM | #8 |
Re: factory tach???
uugghhh! all that work, and I can't get it to work???? it worked in the truck I pulled it from, and now there is nothing?
so I went and did some research and I might need to wire in a resistor. Will let you know what happens... Last edited by bark; 05-29-2012 at 12:43 PM. |
05-29-2012, 01:44 PM | #9 |
Re: factory tach???
Most '03 and newer PCMs will need a pull up resistor, a 680 ohm 1/4 watt resistor placed between the power and signal wires on the tach.
