Old 02-06-2013, 10:38 PM   #1
tbrown5079
chevelle rear
What is the most economical way to match the newer 4L60 transmission to an older Chevelle rear and yoke? I know there are ujoints with 2 different size ends but don't know the numbers. The driveshaft will be 53". The local machine shop will shorten a shaft for $72 which doesn't sound too bad. What did everyone else do?
tbrown
tbrown5079 is offline   Reply With Quote
Old 02-06-2013, 11:21 PM   #2
NEWFISHER
NEWFISHER's Avatar
Re: Mating a 4L60 to a Chevelle rear
Th350,400,200,700 and 4l60 are 27 spline. I used a stock 92 S10 blazer 4x4 4 door rear shaft that is 52 inches long, slid it into the 700 and used a conversion joint that was in stock at the parts store to 1310 common 67-72 truck rear axle ( but was the most common ujoint in GM vehicles from what I hear. Bolted it in and hit the road. It took me 3 lunch hours with a tape measure to figure it out though.
I think I have $47 in the driveshaft and the joint
NEWFISHER is offline   Reply With Quote
Old 02-07-2013, 12:21 PM   #3
tbrown5079
Thanks, that's what I wanted to hear.
tbrown
Old 02-26-2013, 04:49 PM   #4
tbrown5079
Thanks to NEWFISHER on the driveshaft install. Got 2 conversion joints, had a yoke and got a 53" shaft from a friends pile of parts for $10. Less than $50 invested but need to replace the slip yoke I borrowed. I love this site!
tbrown
Old 02-26-2013, 06:08 PM   #5
NEWFISHER
NEWFISHER's Avatar
Glad you got it done and yes, this site rocks!
