05-31-2013, 10:19 PM | #1 |
backspacing ?
Hey guys I have a 68 short that I am changing the axels to 5 on 5 can anyone tell me what is a good backspace for the wheels/tires to come out far enough I will be running 20x10 or 22x10 0n a 5/7 static. Thanks
05-31-2013, 10:55 PM | #2 |
Re: backspacing ?
subscribed
1972 longbed- 454 1967 shortbed- 355 |
05-31-2013, 11:10 PM | #3 |
Re: backspacing ?
I had 20x8 on a 5.5"bs and they scrubbed on a 4" front drop.
I was running fender wells. Are you? Posted via Mobile Device
68' c10 stepper 5.3/4L60e Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917 |
05-31-2013, 11:24 PM | #4 |
A day late and $1 short...
Re: backspacing ?
Is the truck a step or fleet? This greatly affects fitment and backspacing. I have a 68 Step bed with 4.5/6 drop and my wheels are 20x8.5 w/5.25 bs and 22x9 w/5.50 bs. (I have the later (70 1/2-72) long rear axle.) With the stock width rear axle I was going to use a 5.0 bs.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
06-01-2013, 04:30 PM | #5 | |
Re: backspacing ?
06-01-2013, 05:03 PM | #6 |
Re: backspacing ?
You need to figure out what axle you have for sure. If it's the narrower axle I'd say 4.75-5"
Posted via Mobile Device |
06-01-2013, 05:26 PM | #7 |
Re: backspacing ?
Wow, what size tire were you running? I've got 20x8.5 w/ 5.25bs up front wrapped in 255/40/20 on a 5.5" front drop and only rub the drivers side inner fender on ocassion. It's avoidable if I pay attention and drive responsibly.
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped 1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant |
06-01-2013, 05:33 PM | #8 |
67-72 parts collector,…
Re: backspacing ?
The is member 72BlckButy's '69 swb.
20x8.5 (5.5" BS) 255/40-20 20x10 (4.75" BS) 295/40-20 Early 67-69 width rearend. (narrower than the 70, 71-72 rearend)
06-01-2013, 08:56 PM | #9 |
Re: backspacing ?
^^Sweet set up right there.^^
06-01-2013, 11:49 PM | #10 |
Re: backspacing ?
I have 20x8.5 with 5.5" BS all around. I had to put a 1.5" spacer on the back but the front was fine. Tires are all 265/50/20's. most of the new wheels were 5.25BS or more that I found.
'67 2wd LWB 350/4speed. |
