Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 05-30-2013, 06:09 PM   #1
alabama mike
alabama mike's Avatar
Uh-oh, might have problems
Drove my old 65 c60 yesterday, had just finished rebuilding the brake system and wanted to do a road test, so I guess I put about 25 miles on the old truck, ran great quiet as a mouse, we'll I went to move it this morning and I've developed an engine noise, I'm defiantly sure its not a bearing, I've had rod and mains turn in engines before and know the noise well, I'm leaning toward a lifter or rocker, I've had rocker studs pull out of heads before, but is it possible to lose a lifter from one day to another? gonna head out and pull the valve cover and check rockers for tightness, anybody have any thoughts? I never seem one develop a noise like this one day to another.
Disabled Vet, Desert Shield/Desert Storm Veteran
"Proud to have served"
1965 C-10, 1965 C-60, 1966 C-10, 1975 C-20, 1986 M1009 Blazer, 1987 GMC 1/2 ton suburban, 1995 1500 Suburban 4x4, 2001 2500 Suburban 8.1L
alabama mike is offline   Reply With Quote
Old 05-30-2013, 06:14 PM   #2
alabama mike
Re: Uh-oh, might have problems
and another question, if I decide to swap motors, would my trans live behind a mind 454?
Old 05-30-2013, 06:54 PM   #3
alabama mike
OK this is what I found, was #6 intake, had to happen on startup because the truck was quiet yesterday, any ideas as to the cause?
Old 05-30-2013, 07:34 PM   #4
nknspqs
Water leaked into the cylinder ? over night.......
nknspqs is offline   Reply With Quote
Old 05-30-2013, 09:15 PM   #5
66Submarine
66Submarine's Avatar
Really old varnished fuel + a low mileage engine with tight valve guides? Is the valve still stuck?
66Submarine is offline   Reply With Quote
Old 05-31-2013, 08:10 AM   #6
alabama mike
Valves not stuck now, after the bend truck was still running, no miss, just the noise, valve was opening, just the rocker arm was hammering, had to pull the side cover off the get it out. I had thought I had lost a lifter, never had one do this to me.
Old 05-31-2013, 12:38 PM   #7
alabama mike
Well after working on the truck this morning the same valve stuck in the open position, so now I know the cause, been spraying it with PB blaster and gentle tapping on the valve, the valve finally closed on its on. I disconnected the coil and rolled the motor over several times, seems to be working fine right now, I guess time will tell. I like the big 6, but might still go with a 454, then I can build the 292 and put it in my 66 c10
Old 06-03-2013, 09:23 PM   #8
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Bummer on the bent PR/ sticky valve(s). IMHO, 454 might be
easier than your 292, when parts shopping or adding accessories.
my 2¢ & Subscribed
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 06-04-2013, 08:55 AM   #9
alabama mike
I'm leaning that way right now, I have a fresh 454 in a 1975 c20 that is not being used, I have a good 350 sitting in the barn, I'd like to put the 350 in the c20 then sell it, 454 in the c60, and then replace the 250 in my 66 c10 with the 292, looks like I have alot of work ahead of me!
Old 06-04-2013, 11:30 AM   #10
ETsC10
Hand Crafted C-10
ETsC10's Avatar
292's rock in street trucks!
Truck FAQ
