09-01-2013, 12:06 AM | #1 |
speedometer help
Hello, I am in need of some advice, I really need to get the speedo working in my truck before I get nailed for driving to fast...
I have a 77 chev, it has 295/50r-15 rears, running 3:73 gears, I installed a 700r4 from a 93 truck into it, had an electric gauge drive, so switched it over to the bits from an 80's 700r4 with mechanical drive, the speedo sits pegged all the time, if I put a ratio adapter in it slows it a bit but still not close. Where do I start? what gears do I need on the tail shaft, and speedo drive gear? or am I hooped with the ratio/tire size I am running any help would be great thanks |
09-01-2013, 03:43 PM | #2 |
Active Member
Re: speedometer help
To keep from getting a ticket you could borrow a GPS to see what your speed actually is.
There's a transmission/speedometer site that tells you what you need to check but I don't have the url handy. Maybe someone else can post it for you.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
09-01-2013, 08:17 PM | #3 |
No No
You need to figure out how fast you are going before you can decide on speedo gears. GPS would be great for that. http://www.transmissioncenter.net/sp...n_______va.htm
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
09-01-2013, 10:48 PM | #4 |
ya I have carried my gps, and cruising speed is around 2200rpm, but I have unhooked the speedo drive, cause it just bounces off the peg all the time.
will look into the transmission center thanks |
09-02-2013, 09:18 AM | #5 | |
Active Member
Let us know how you do.
