Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-15-2014, 07:09 PM   #1
flyingcubby
Radios fr 71 blazer
Just a quick question, Can someone tell me which years of GM radios will fit the original opening.. I change it to an audiovox in the late 70's and now want to make the dash look original as possible without a lot of cash ... Thanks in advance
flyingcubby is offline   Reply With Quote
Old 02-16-2014, 12:25 AM   #2
ray_mcavoy
Re: Radios fr 71 blazer
To make it look as original as possible, you'll want a radio from a 1967 - 1972 GM pickup, Suburban, 69-72 Blazer, or 70-72 Jimmy. I believe the GM G-series vans also used a very similar radio from 1971 up into the 1980's.
There are probably other GM radios that will fit too. The key measurements are the shaft center-to-center spacing of 6-1/4" and the center rectangular opening of 4-1/2" x 2-1/4". That rules out a lot of the later GM radios (like the ones used in 73-up trucks for example) because those have a narrower 5-3/4" shaft spacing.
ray_mcavoy is offline   Reply With Quote
Old 02-16-2014, 12:07 PM   #3
flyingcubby
Thanks for the info...... Mike
