03-15-2014, 04:16 PM | #1 |
Shock relocation kit?
If I lower the rear of my 64, 4 inches do I need to put a shock relocation kit on it? And an adjustable tracking arm?
03-15-2014, 04:19 PM | #2 |
67-72 parts collector,…
Re: Shock relocation kit?
I say 5" or 6" drop needs them.
Never done a 4" drop. Look at your shock angles when you are done and check if the rearend is still centered in the frame. That will tell you the real answer.
03-15-2014, 04:45 PM | #3 |
03-15-2014, 10:15 PM | #4 |
I would do the relocating brackets if the 4" drop is w/just springs. Blocks & springs I wouldn't bother.
03-16-2014, 12:03 PM | #5 |
03-16-2014, 12:11 PM | #6 |
03-16-2014, 05:35 PM | #7 |
How about if you replaced the stock shocks with lowering shocks do you still need the reloctation kit?
03-17-2014, 09:16 AM | #8 | ||
Drop blocks in a truck-arm application don't impact shock travel since they only alter the position of the rear end housing.
