Old 06-13-2014, 10:10 PM   #1
twouvakind
twouvakind's Avatar
Source for return spring(s)
I have a 350 with a qjet. I am trying to locate the proper throttle return spring(s) I do have the tang on the thermostat housing. Any ideas?
twouvakind is offline   Reply With Quote
Old 06-13-2014, 10:25 PM   #2
bigd65
bigd65's Avatar
Re: Source for return spring(s)
Orielys or any auto parts stores will have the double spring in the MOTORMITE / HELP section
2004 Silverado Crewcab (Dark Spiral Gray)
bigd65 is offline   Reply With Quote
Old 06-13-2014, 10:35 PM   #3
twouvakind
twouvakind's Avatar
Sounds simple enough though NAPA was clueless-zero help. Thank you.
Anyone got a Dorman/Motormite part number?
Old 06-13-2014, 10:51 PM   #4
magicoolbus
magicoolbus's Avatar
http://www.jegs.com/p/Mr-Gasket/Mr-G...43779/10002/-1
http://www.summitracing.com/parts/rn...FRWVfgodvQYAMA
http://www.rbinc.com/p-5218-59209.aspx?origin=keyword
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 06-13-2014, 11:20 PM   #5
franken
Sorry the NAPA was useless. I have an O'Reilies person like that.
http://lmgtfy.com/?q=throttle+return+spring
Same w/ clutch return springs. Whaat??
Old 06-14-2014, 12:32 AM   #6
twouvakind
twouvakind's Avatar
"I am here by myself" so ended that conversation.
Old 06-14-2014, 12:39 AM   #7
Gumby
Gumby's Avatar
should be right on the shelf in that doorman or similar section of all kinds of clips, odds n ends for cars in tiny packages.
If you want to save gas, I used a screen door spring once.
part throttle took effort, took a muel kick to get all 4 open
Gumby is offline   Reply With Quote
