Old 07-31-2014, 11:55 AM   #1
gramps77
A-arm bushing swap
I purchased these http://www.summitracing.com/parts/en...olet/model/c10
Are there some things I need to make sure and do or look out for? Or just a straight swap? I have heard not to use the lubricant in the box.
Almost forgot, will a 2000 pound workbench arbor press get the old ones out?
gramps77 is offline   Reply With Quote
Old 07-31-2014, 03:51 PM   #2
mattcrp1
mattcrp1's Avatar
Re: A-arm bushing swap
I did a write up on the install of bushings. Check my sig for the link.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 08-01-2014, 10:31 AM   #3
Aaron_L
I think with the Energy Suspension kit you have to knock the shells out too. I usually heat the shell with a small torch until the bushing starts to "boil", then hit it with an air hammer. The bushing will come flying out, sometimes on fire, which is fun for all. If I have to change the shell, I'll change the tip in the air hammer to a chisel and split the shell, then knock it out. A press can bend the control arm if you're not careful.
Aaron_L is offline   Reply With Quote
