If you've ever had windshield replaced read this
Just wanted to alert others to a problem I learned the hard way.
Took my truck to my body shop who repainted the roof 2 years ago. The leading edge of the roof in the middle right at the windshield had rust showing underneath the paint. He explained that when I had a new windshield installed some years back the tool that breaks the seal between the glass and the frame had scratched the paint under the windshield on the frame down to bare metal. Glass shops don't care and just slap in the new windshield with out doing anything to the bare metal. The rust then creeps out from under the glass to the surrounding metal. He had a toyota just the week before that required new metal work under the windshield. The work that I need is not terribly expensive $550 to remove the windshield, clean and paint the frame and the roof and that includes the price of a new windshield as they anticipate breaking the old one on removal. But it's still $550 I should not have to spend. So be sure you have a low deductible on your insurance before you go in for glass removal. |
![]() Join Date: Nov 2013
Re: If you've ever had windshield replaced read this
Sounds like you had A bad seal. A seal is suppose to keep water from getting underneath the seal. Maybe bad or cheap seal. Painter might have not sanded/ sealed window channel befor painting ??
Wow! I pay $150 for my windows installed. but then that does leave them $400 to paint it so I guess that is about right. Knowing there is rust work to do I do take back my Wow. Sometimes I see what people are quoted on some stuff and think if I did that at my body shop I wouldn't be able to sleep at night. But then i would have some money to buy me something to make me sleep
Luckily, my last windshield replacement on my truck was while it was still in the bodyshop.
They have a primer that they are suppose to paint on the bare metal spots created by their extractor. Some glass guys are butchers and most are just plain lazy. I have a friend who is a great glass guy and he is the only one I trust with my stuff.
I have seen a glass guys bust a big whole in the roof seam of a car with an extractor. |
Nope the seal on the top was perfect. He stated no matter what the seal does, it's going to rust.
driving is in my blood
Move to AZ. Rust problems solved.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
RIGHT! You never see rust on cactus...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
That is all it takes even a chip in the paint in a area that gets wet...the rust starts creepn
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
I've worked in auto glass and have a close friend who owns an auto glass business. The original explanation given to Speedy is correct. The extractor often scratches the paint and lazy installers don't prime the scratches. If the window was done well the last time or hasnt been done a bunch of times it is a lot easier and usually leaves no scratches. End of the day it's a due diligence thing so if you don't trust your installer keep an eye on him or ask him to prime it anyway even if he doesn't think he scratched it. The trim covers the primer completely in most vehicles anyway.
1991 R3500 3+3 C+C 6.2/4l80e/14ff Fleetside Dually 1992 K2500 ECLB 5.7/4l80e/14sf(g80) 8600gvwr 1991 CR500 (95 Burb wouldn't stop catching fire ![]() |
I own a auto glass co. in Oklahoma City, I do 88-98 trucks all the time. GM set us up for doom from the start, they put this strip of foam on the leading edge of the roof all it does is hold dirt and water, there are glass guys and those who think they are, you have to prime the windshield anyway or the glue doesn't stick to it because of the encapsulation. 2 out of 5 of them I do have never been touched and you pull the glass to find a rusty pinch weld. YES a shotty glass guy could make one leak and rust, I prime every one I do. I do it right the first time, that's the only way to expect to have return customers.
To some it up they all rust, I've done 2 in 9 yrs. that had no rust I primed them anyway |
My 1991 GMC Sierra got a new windshield form Safelite Of Birmingham, Ala. They came to my work location and I watched as the old was taken out (not broken} and the new replaced. Very professional and a great seal with no scratches..
Tags |
frame, rust, windshield |
