08-17-2009, 11:52 PM | #1 |
2" Drop Trailing arms
Well, I finally have the tubular dropped trailing arms the way I want them, and figured I would post up some "spy pics". I won't be officially releasing them for another week or so. These are for a board member's blazer project.
They are 2" DOM tubing with a 2" drop built in. They will be compatible with either coil-springs or an airbag. The front joint is a polyurethane flex joint (rebuildable and greasable). They are compatible with factory, factory replacement, or Porterbuilt trailing arm crossmember. I have a few tricks up my sleeve for the Porterbuilt trailing arm x-member and will be running a special on the set-up.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
08-17-2009, 11:59 PM | #2 |
Wide n'Low
Re: 2" Drop Trailing arms
Very Nice!! Another awesome addition to your product line, and we will all be looking at your upcoming package deals...
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
08-18-2009, 12:25 AM | #3 |
It'd be alot cooler if you did
Very nice.
08-18-2009, 01:14 AM | #4 | |
Those look really cool...I like the flex joint it should be nice and quiet, may I ask what the bolt size is?
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
08-18-2009, 06:07 AM | #5 |
67-72 parts collector,…
subscribing,...
08-18-2009, 09:31 AM | #6 |
Board members Blazer project?? What am I . . .... chopped liva?
08-18-2009, 09:50 AM | #7 |
///Relaxed Atmosphere
look very nice
72 Suburban 64 Chevy short fleet 04 Chevy Colorado Sport Reg Cab 2012 Chevy Avalanche 2003 Chevy S10 Blazer Xtreme http://www.hubgarage.com/mygarage/RA_Jeff 64 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=295915 |
08-18-2009, 10:01 AM | #8 |
Can you actually believe that there was somebody else who has been bugging me longer for a set of these than you!
08-18-2009, 10:05 AM | #9 | |
The factory arms have a 3/4 through bolt, and the factory bushing is slightly wider than this flex joint as well. The solution to adapting these arms to a factory x-member are a couple small machined adapter spacers that will be included. If the arms are purchased with the Porterbuilt trailing arm x-member then there will be no need for the machined adapter pieces. Pics of the trailing arm x-member to be available for this kit should be surfacing soon....
08-18-2009, 11:48 AM | #10 |
Village Idiot....
I would be more than happy to "test" these for you.....I would even do it for free.....since where buddies and all.....
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
08-18-2009, 12:07 PM | #11 |
I don't believe it . . ....
08-18-2009, 12:47 PM | #12 |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-18-2009, 01:11 PM | #13 |
Keepin it old school
pretty slick
08-18-2009, 02:11 PM | #14 |
Phone's ringin Dude.
Those would be sweet with a nice Watt's link.
I pitty the fool with only two headlights!! 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL Last edited by dieselarmy13; 08-18-2009 at 02:12 PM. |
08-18-2009, 03:17 PM | #15 |
The LuvShack Garage
So when will these be at my door? Last edited by LUV2XCLR8; 08-18-2009 at 03:55 PM. |
08-18-2009, 03:27 PM | #16 |
Didn't I tell you "two weeks" already?
08-18-2009, 04:47 PM | #17 |
08-18-2009, 06:17 PM | #18 |
Señor Member
Is your jig flexible enough to move the spring pad forward?
... not sure why I am asking? I'm currently out of money.
08-18-2009, 07:33 PM | #19 |
big guy
Nate how will they work with a super trac bar from early classic enterprises? does it affect anything else? Even with these, is the frame still going to be your limiting factor ( how big of a notch) of how low you can go.
Ray |
08-18-2009, 07:42 PM | #20 | |
08-19-2009, 12:17 AM | #21 | |
After buying Kevin all that nice shiny shop equipment, I can only imagine how thin the wallet is!
08-19-2009, 12:22 AM | #22 | |
The trailing arms will still have the same contact issues with the frame if hoping for an extreme drop. This will still leave the rails a few inches from the pavement.
08-19-2009, 12:22 AM | #23 |
I wasn't.... but should I be!?
08-19-2009, 12:30 AM | #24 |
Unless you modify other stuff. Tic-Toc, tic-toc . . .....
08-19-2009, 06:32 AM | #25 |
big guy
tic-toc tic-toc you ant kidding, and it's not all about suspension. I mean you have your motor out so you can install the drop member so why not do a little something on it, then the trany, maybe some new parts, how about some paint.... on and on we go! LOL Nathan build's some super nice stuff and everything is cutting edge, i love it. Some times i think to nice and my wallet can't keep up!
Ray |
