07-06-2015, 05:54 PM | #1 |
Sold Motor mount perches
Sold Thnaks
Motor mount perches from what I understand they will fit I6 except 292 or SBC V8's. These came off of a 1965. $25.00 Shipped in the lower 48.
It only has original paint once Last edited by Mathew21; 01-27-2016 at 09:59 PM. |
07-06-2015, 08:46 PM | #2 |
Re: Motor mount perches
We would be interested in these if you or someone else could tell us if they will work in our 66 k20. We took out the six cylinder and are going to replace it with a sbc 350. Thanks evan
07-06-2015, 11:00 PM | #3 |
60-66 Nut
These are for a C series truck. The K series trucks use a totally different engine mount bracket. If you are having trouble finding original '60-'66 K series engine mount brackets, you can use the engine mount crossmember from a '67-'72 K series. Just drill the holes and bolt it in. If the I6 you removed is a 230/250, you do not need to change anything.
07-06-2015, 11:13 PM | #4 | |
Here's a good link about perches for our trucks http://www.persh.org/pickup/perches.htm
It only has original paint once |
01-26-2016, 11:06 PM | #5 |
ttt
01-27-2016, 07:29 PM | #6 |
I will take them !! Sold !!
There is more then one way to do it right ! |
