Old 01-06-2016, 08:17 PM   #1
OldChevy61
OldChevy61's Avatar
Harmonic balancer
In the process of my 350 build and was wondering how does one go about choosing the correct harmonic dampener. There was not one with the block when I got it. Its an 86,87,OEM roller block,1 piece rear main seal.. Looking at summit, I see internal and external balance .
OldChevy61 is offline   Reply With Quote
Old 01-07-2016, 12:13 AM   #2
GM-power
GM-power's Avatar
Re: Harmonic balancer
Depends on what crank your running, if it's internal/external balance from the manufacturer. I'm assuming it's a gm crank, I believe the 1 piece uses a internal balance balancer and a external balance flywheel. If your not sure take the rotating assembly to a machine shop. Might not hurt to have it checked out, and they can let you know what you need.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 01-07-2016, 12:58 AM   #3
storm9c1
*** That's interesting ***
storm9c1's Avatar
Right, I agree, normally a 1-piece seal stock crank cuts into the counterweight space, so additional balance weight is needed on the flywheel. But front balancer is neutral. On a truck, I'd run a 8".
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 01-07-2016, 01:24 AM   #4
Captainfab
60-66 Nut
Additionally the timing mark on the balancer will need to correspond with the timing pointer being used.
Old 01-07-2016, 02:04 AM   #5
storm9c1
storm9c1's Avatar
Oh yeah I meant to say stock timing tab for a truck corresponds to an 8" balancer. Excellent point! If this engine is of unknown origin, either replace the pointer with a known good one based on the balancer size you need or measure/compare/verify the markings against a known good one.
I also second the advice of taking it to a machine shop. If this is an unknown engine, the right thing to do is balance the whole rotating assembly together as a unit (flywheel, crank, balancer, et al). I know that's not ideal in this case if you are already far along, but that's exactly what's done when the engine is built. That being said, you should be OK with bolting on a new balancer and skipping that step. No need to create more work and spend more money. But if you have a vibration, you will be pulling it back out and doing that anyways...
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
Old 01-07-2016, 08:16 AM   #6
OldChevy61
OldChevy61's Avatar
Thanks guys. I'm a little beyond just grabbing it and running it to town, but I will be headed to the machine shop that done the work on it this morning.
