Old 06-23-2012, 12:42 PM   #1
crossfire84
crossfire84's Avatar
LIL ERV the 50
Well, here she is our 50, these photos are a ways into the build. The frame is almost done here, front end is a 1985 c-10, rear end is a 1985 corvette. If I can find the disk with the photos from the start will post.
crossfire84 is offline   Reply With Quote
Old 06-23-2012, 01:18 PM   #2
crossfire84
Re: LIL ERV the 50
just finished with the mar-k hidden hinge and latch, very nice. the only thing i dont care for are cheap plastic red knobs, will make a set of stainless ones at work.
Old 06-23-2012, 08:54 PM   #3
crossfire84
Re: LIL ERV the 50
cut the cancer out of door bottom, welded in new piece.
Old 06-26-2012, 08:51 PM   #4
crossfire84
Re: LIL ERV the 50
time to cut 9" out of the frame. good bye long box, hello short box!
Old 06-26-2012, 09:00 PM   #5
crossfire84
Re: LIL ERV the 50
made the "z" cut and brought the two pieces together.
Old 06-26-2012, 09:02 PM   #6
crossfire84
Re: LIL ERV the 50
time to get some welding done.
Old 06-26-2012, 09:22 PM   #7
crossfire84
Re: LIL ERV the 50
all welded up and 2 plates on the outside of frame.
Old 06-27-2012, 11:44 AM   #8
solidaxel
solidaxel's Avatar
Re: LIL ERV the 50
I think you should bring that to Mar-K attention....................... When I bought my tailgate and assembly from them a few years ago they were supplied with a aluminum knob.
I would ask them to bring them back for the cost Vs. there "Quality" products.
Just sayin !!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-27-2012, 03:22 PM   #9
MAR-Ktech
Truck Parts Mfg.
MAR-Ktech's Avatar
Re: LIL ERV the 50
All Mar-K hidden latches have the aluminum knob that you can twist to hold them in the open position. This unique feature is very convenient as you do not need to hold both latches open at the same time to open or close the tailgate. Other suppliers may offer a less expensive latch but if it does not have the aluminum knob that you twist to hold it open, it is not a Mar-K latch. http://www.mar-k.com/product_comparison.aspx#latches.
GET MAR-K Quality!
Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks
MAR-Ktech is offline   Reply With Quote
Old 06-27-2012, 05:36 PM   #10
crossfire84
Re: LIL ERV the 50
[QUOTE=MAR-Ktech;5457526]All Mar-K hidden latches have the aluminum knob that you can twist to hold them in the open position. This unique feature is very convenient as you do not need to hold both latches open at the same time to open or close the tailgate. Other suppliers may offer a less expensive latch but if it does not have the aluminum knob that you twist to hold it open, it is not a Mar-K latch. http://www.mar-k.com/product_comparison.aspx#latches.[/QUOTE
I bought the hinge and latches from brothers. The hinges are mar-k with their instruction sheets, the latches were in the same box so I thought they were mar-k also, I see that there not, my apologies to mar-k, I have their box and its top notch first quality, next time I will read the ad more carefully.
Old 07-03-2012, 07:40 PM   #11
crossfire84
Re: LIL ERV the 50
ok, i found my disk of photos of the start, here it is in fargo ND in all its glory.
Old 07-03-2012, 07:44 PM   #12
crossfire84
Re: LIL ERV the 50
At home now not to bad looking.
Old 07-03-2012, 07:46 PM   #13
crossfire84
Re: LIL ERV the 50
Time for the tare down.
Old 07-03-2012, 07:51 PM   #14
crossfire84
Re: LIL ERV the 50
My new front saddle from a 1985 C10.
Old 07-11-2012, 05:53 PM   #15
crossfire84
Re: LIL ERV the 50
Fixed the door and pulled off spindles and a-arms, have new 3" drop spindles and having new bushings pressed in a-arms.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
Old 07-11-2012, 11:00 PM   #16
Wybrow
Re: LIL ERV the 50
You are off to a great start, I'll be shortening my long bed as well, it's nice to see the pictures of what you did, looks great.
Wybrow is offline   Reply With Quote
Old 07-12-2012, 03:47 AM   #17
crossfire84
Re: LIL ERV the 50
thanks.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 07-12-2012, 01:14 PM   #18
_Ogre
_Ogre's Avatar
Re: LIL ERV the 50
glad you saved it, good looking truck
looks like mother earth was trying to suck it down and reclaim it for her self
shop air compressor timer
Old 07-12-2012, 08:35 PM   #19
crossfire84
Re: LIL ERV the 50
Last time it was on the road was 1973! Picked her up in 2004 there abouts.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 07-19-2012, 06:25 PM   #20
crossfire84
Re: LIL ERV the 50
New borgeson steering shaft and stainless joints.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 08-03-2012, 07:02 PM   #21
crossfire84
Re: LIL ERV the 50
new bell-tech 3" drop spindles and 3" drop coils.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 08-03-2012, 11:59 PM   #22
meter swinger
meter swinger's Avatar
Re: LIL ERV the 50
Looking good man.
did you have to do any grinding on the lower control arm after the 3" spindle?
meter swinger is offline   Reply With Quote
Old 08-04-2012, 11:57 AM   #23
crossfire84
Re: LIL ERV the 50
Originally Posted by meter swinger View Post
Looking good man.
No grinding at all, these are the stock 15" wheels, clearance all the way around.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 08-04-2012, 03:18 PM   #24
99 to Life
99 to Life's Avatar
Re: LIL ERV the 50
so the front clip just bolted right up? I'd like to hear more about that set up. First one I seen using this.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 08-04-2012, 07:30 PM   #25
crossfire84
Re: LIL ERV the 50
the 85 saddle is 1/2" wider than the 50 frame rails, so i just made a pair of 1/4" steel plates to slide down each side of frame. this does move the wheels out a bit on each side, but you can offset the wheels when you order them from any wheel company. i paid $60 for the complete front clip from the junk yard. some people will cut the saddle in half and remove the required amount and weld it back together to keep the wheel width the same.
Any saddle from 68 to 87 will fit.
LIL ERV the 50-3600
C4 rear
Porter built a arms
