03-12-2017, 09:49 PM | #1 |
Vin decode isn't working on my truck.
My trucks vin is cce242b118444.
1972 Chevy 4x4 K10. But the decoder doesen't match up with my vin. Help is appreciated thanks. |
03-12-2017, 09:56 PM | #2 |
Re: Vin decode isn't working on my truck.
The vin tag is for a 72, 3/4 ton, 2wd.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
03-12-2017, 09:56 PM | #3 |
Your truck is a v8 2wd not a K10
03-12-2017, 10:00 PM | #4 |
Okay but it has 4x4. I have used it. It has 6 lug axles front and back, and a transfer case and locking hubs. The first two characters of my vin are CC, how could that be? It also has drum brakes front and back. I am very confused on all this haha.
Posted via Mobile Device |
03-12-2017, 10:02 PM | #5 |
If you follow the vin decoder, having the first two characters be CC nakes no sense, also look at the model year (5th character) it does not match up either.
03-12-2017, 10:03 PM | #6 |
Somebody made a 4x4 with a 2wd truck...drum brakes are 1970 and older
03-12-2017, 10:10 PM | #7 |
That still does not explain the vin, the first two characters, or the character for the year, it is a 4. Which isn't listed in the decoder.
03-12-2017, 10:43 PM | #8 |
2 C's is correct for 72, no idea why they did that though. C is for 2wd, E is for V8, 2 is 3/4 ton, forgot what 4 is, 2 is for 72, B is the plant
Sounds like you have a 72 body on a 70 or older chassis. And your vin tag has the wrong rivets, so it's been removed. You should have numbers on the top frame rail near the steering box. Do you have the SPID (option sticker) on the inside of the glove box door? That gives a bunch of info
03-12-2017, 10:44 PM | #9 |
Or you could have the original body and chassis and someone swapped the vin tag?
03-12-2017, 10:46 PM | #10 |
BlahBlahBlah
C Chevy
C 2WD E V8 2 3/4 ton 4 Pickup 2 1972 B Baltimore The rest is the serial number That's how I read the decoders .... http://67-72chevytrucks.com/vboard/s...d.php?t=570059
03-12-2017, 10:49 PM | #11 |
Here's a decoder for your truck.
http://www.vinwiz.com/1972-1980gmtru...=CCE242B118444 Digit Usage VIN Decoded 1 Mfgr C Chevrolet 2 Chassis C 2wd 96 inch or 106 inch conventional cab 3 Engine E V8 gas (307, 350, or 402-4v L47) 4 Series 2 3/4 ton 5 Body 4 Pickup 6 Year 2 1972 7 Plant 2 Baltimore MD 8-13 Sequential Serial # 118444 118444 |
03-12-2017, 11:28 PM | #12 |
No glove box. But the frame reads 0T114217
03-12-2017, 11:32 PM | #13 |
Idk if that helps but I hope it does.
03-12-2017, 11:36 PM | #14 | |
Is the rear-view mirror glued to the windshield? Are there little screws by your windvents? Are the door panels all plastic with molded in armrests? If all YES then it's likely a '72. Probably ''KE140T114217" was the original truck's VIN before the chopshop got to it.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 03-13-2017 at 12:19 AM. |
03-12-2017, 11:38 PM | #15 |
Yeah... that's proof positive they don't match. The last #'s on the frame should match the build sequence of the truck. If I'm reading that right, the frame is for/from a 1970 (0) T (Terrytown Plant) with a sequence # of 114217. The sequence on your VIN is 118444.
Given your location (VA) and the need for 4x4s up there and how short of a time frame before a body is bad... 4x4 frame swaps happen all the time. The body probably went to crap and they found a nicer 2wd truck with a title and used that.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
03-12-2017, 11:38 PM | #16 |
Where did you find this out? So I know for future refference. Also, does that mean my frame came from the factory 4x4?
03-12-2017, 11:41 PM | #17 |
Thanks for all the help by the way guys.
03-12-2017, 11:47 PM | #18 |
That's actually just one of those things you have to know/find out from research, but basically frames just have the plant, year, and build # on them.
It's not proof positive it's a 4x4 frame, but it is a pain in the ass to convert a 2wd frame into a 4x4 frame, so it's highly likely it's a real 4x4 frame.
03-13-2017, 12:13 AM | #19 |
Also found 3975197 160 1119 12 on the frame.
03-13-2017, 12:24 AM | #20 |
Just a GM part number.
03-13-2017, 12:30 AM | #21 |
Transfer case says 14008224
03-13-2017, 12:30 AM | #22 |
Most Chevy C/ series , 4x2s were built with coil springs. All Chevy and GMC K/ series trucks [4x4s] were built with leaf springs. If you have leaf springs the chassis is original, the cab [or VIN tag] was replaced. Like Redneck says, it's very unlikely anybody went to the expense and trouble to make a ''K'' out of a ''C''.
03-13-2017, 12:35 AM | #23 |
I have leafs, and the shackles are riveted not bolted, and show the patina a truck from '70 would. I'm thinking it's a 4x4 frame.
03-13-2017, 12:38 AM | #24 |
Tried posting a vid but it didn't work.
03-13-2017, 12:40 AM | #25 |
I don't have a reference to find that p/n.
If you're lucky, you might have an NP205 Xfer Case. Good unit. Period correct. Bombproof, geared assembly. Parts available. If not, it could be a Rockwell T-221, Reliable, but noisy. Hard to source parts. Or the NP203 [works on an interior drive belt] mechanically unreliable.
