Old 11-25-2007, 10:06 AM   #1
tbrown5079
56 Cameo build
I am just getting into a 56 build for a daily driver. I have all the origional fiberglass to make it a Cameo.
This is my second build, as I have a 40 truck with pacer front end, 350, 9" ford rear, saginaw 3 speed, etc. It looks origional but everything but the sheet metal has been changed. I've been driving it for over ten years and decided I had better get started on another truck before it"s too late. I have some good friends who are very talented and give me help and advice. This is a great hobby.
Back to the 56. I'm posting some pictures and hope to keep this going, but I'm not going to be as quick as some of you.
We installed an elcamino front clip ( I knew the guy that had it and was in good condition), did the motor and transmission mounts with dummy block and transmission, put the c-notch in the frame, installed the blazer springs and rear, and cut the cab for the big rear window.
I have a summit tank, new leather seats donated by a good friend, steering column, and a few other things collected.
I'm going to have a ton of parts to sell along the line, ( pretty much an entire front clip,cameo bedsides with brackets, doors, tank, etc)
I hope to get the cab in good shape and mounted over the winter.
I enjoy this site and hope I can contribute to what you all have started.
tbrown5079 is offline   Reply With Quote
Old 11-25-2007, 11:05 AM   #2
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 56 Cameo build
Sound like it's going to be a sweet ride, but I gota ask, your selling your Cameo bed? Are you not going to keep her a Cameo?
CAL 58 GMC is offline   Reply With Quote
Old 11-25-2007, 11:18 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: 56 Cameo build
Looks good so far how about some sheet metal shots. Are you going with a step bed?or cameo?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-25-2007, 12:38 PM   #4
tbrown5079
Re: 56 Cameo build
I have 2 sets of Cameo sides with brackets, so I will sell one set. I just stumbled on to the second set which is a little better, so I swapped some stuff for it.
Old 11-25-2007, 02:21 PM   #5
entourageguy
Yellow truck club
entourageguy's Avatar
Re: 56 Cameo build
Looks like a good start to an interesting build.
Brian
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 11-25-2007, 04:42 PM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: 56 Cameo build
Looks like this will be getting interesting, be sure to keep us posted on your progress.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-25-2007, 05:20 PM   #7
55dude
55dude's Avatar
Re: 56 Cameo build
what year is the clip from? it looks like a 80' and a very nice job. i had a 56' cameo 25 years ago and if the trim had been in better shape i would have kept it. keep the pic's coming and the 40' is sweet also.
55dude is offline   Reply With Quote
Old 11-25-2007, 08:02 PM   #8
tbrown5079
Re: 56 Cameo build
It was an 81 El Camino. The guy that did the install built modifieds for years and is soo meticulas. He did all the underneath work on the 40.
Old 01-09-2008, 03:54 PM   #9
tbrown5079
Re: 56 Cameo build
It's been a while but I know how you all like pictures, so here is my progress to date. Got the big back window panel through Paul's GMC parts. Finishing the bottom door hinges before we get started on that. Does anyone know of anyone making the bracket for the cowl where the top of the fender bolts?
Old 01-09-2008, 04:21 PM   #10
magsnubby
magsnubby's Avatar
Re: 56 Cameo build
Do you have a link to Paul's GMC Parts web site?
It's kind of hard to tell from the picture but it looks like the back panel is spot welded on? I've always wondered how much work it would be to convert one to a big window.
magsnubby is offline   Reply With Quote
Old 01-09-2008, 04:53 PM   #11
tbrown5079
Re: 56 Cameo build
Just go to GMCPauls truck parts and it should come up. The only problem may be the bracing under the panel is different around the door jam. I got the roof, window, and back panel inside and out for a big window. I just got the new outer panel so I wouldn't need so much body work. You would also need the inner panel which is available.
Old 01-09-2008, 05:07 PM   #12
pugs
pugs's Avatar
Re: 56 Cameo build
Hi from the Reading Pa T Brown, looks liek a good start tothe project. I myself will be a proud owner of a 57 w/ 56 front sheetmetal in about a week. Oh its a project, it will be need floors, lower hinge work, cab corners. my plan to set it all on a 88-94 swb chassis, if i had the cash i would be interested in the spare side you got will have to see how things go, but keep us updated tho with the pics
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 02-03-2008, 10:54 AM   #13
tbrown5079
Cool Re: 56 Cameo build
Here are some pictures of the big back window install. Notice the piece you need for the inside that you won't have without a big window cab donor.
need some more work on the door jams before welding it in.
Working on the floorboards that were installed by the previous owner. He left a few pinholes.
A trip to the sandblaster with the fenders and doors. I have five doors to choose from, I hope I got the right ones.
Anybody know where I can get the blocks on the sides of the cowl for the top bolt on the rear fender? Also the brackets in the windshield opening that the windshield rests on?
Old 02-03-2008, 11:42 AM   #14
pugs
pugs's Avatar
Re: 56 Cameo build
its looking good, glad to see ya back at it, just keep the pics coming
Old 02-04-2008, 12:13 AM   #15
FRENCHBLUE72
PROJECT 7DEUCE
Re: 56 Cameo build
Can you show me some pics of what parts you need for sheet metal I have a few cabs going to the crusher....
MEMBER #6377
Project "7DEUCE"
Old 02-04-2008, 12:46 AM   #16
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 56 Cameo build
Lookin good!
Old 02-04-2008, 01:00 AM   #17
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Re: 56 Cameo build
Look at post #9 , 4th picture down. The small piece that goes on top where those holes are. I had to make some for my cab.
Tri5Nerd is offline   Reply With Quote
Old 02-05-2008, 06:58 AM   #18
tbrown5079
Re: 56 Cameo build
Hi Frenchblue. Thanks for the response. Here are the pictures of what I need. I'm missing three of the windshield clips on the passender side. I can make the blocks for on the sides of the cowl if I have to.
Tbrown
Old 02-05-2008, 09:24 PM   #19
FRENCHBLUE72
PROJECT 7DEUCE
Re: 56 Cameo build
Let me look and see what we have .
MEMBER #6377
Project "7DEUCE"
Old 02-08-2008, 09:13 PM   #20
FRENCHBLUE72
PROJECT 7DEUCE
Re: 56 Cameo build
Sorry I dont have those parts wish I could help ya out..
MEMBER #6377
Project "7DEUCE"
Old 02-08-2008, 09:45 PM   #21
tbrown5079
Re: 56 Cameo build
Thanks for the effort. If anyone has an old cab thats not good enough to use maybe they could cut them off for me. I may go to a windshield installer to see if he has any ideas. I was working on the cowl last night, putting in some patches. It's coming together.
Old 02-16-2008, 03:28 AM   #22
tbrown5079
Re: 56 Cameo build
Worked on the rear cab panel last night . Got the roof attached and everything fitting pretty good.
How do you guys fill the gaps on the rear corners? I don't think I'm missing anything, but you could stick your fingers up through the opening. I think when it was new there would have been a heavy cardboard panel behind the seat but was that all?
Old 02-17-2008, 12:04 AM   #23
hotrodsbyray
Re: 56 Cameo build
RE: windshield clips. if you cant find the replacements, talk to a windshield shop about flush mounting it using s-10 molding and rubber support blocks. a lot of folks use them in other type street rods and it might would work here, based on the shape of the channel the glass fits in.
hotrodsbyray is offline   Reply With Quote
Old 02-17-2008, 06:18 AM   #24
pugs
pugs's Avatar
Re: 56 Cameo build
with the gap you mentioned, did ya put new inner cab corners in also
Old 02-17-2008, 11:44 AM   #25
PBFAB.COM
PBFAB.COM's Avatar
Re: 56 Cameo build
I am sure I can help you out on this one. Shoot me a PM with your number and I will call you on Monday. I have a few of these cabs that I am using for parts.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
