LS Swap - Erratic Dakota Digital Temps
Dakota sending unit in passenger head. Everything seemed to work fine during startup and burping the system then it pegged hot instantly. Thought I had a grounding issue, but suddenly started working. Now erratically working and not. Wiring of this gauge and various other BIM units seems sound. Is it possible for a air pocket to cause the issue? I ruled any sort of hear soak issues from header and downpipe our when it started to work during hot operating conditions. When working temp seems dead on with expected temp. Any thoughts or pointers appreciated.
Re: LS Swap - Erratic Dakota Digital Temps
Have you dropped Dakota Digital an email?
I had an issue with a custom unit, and their customer service was top notch. Also, which sender did you use? They offer one with a pigtail they specifically recommend for use with some of their systems and the BIM unit. Last edited by Russ.W.; 05-27-2018 at 01:59 AM. |
Proud Vet that loves the USA
![]() Join Date: Jun 2016
Id check for an air pocket. Mine did the same upon startup/initial driving.
Bubba |
#4 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Temps verified during tuning recently, rigged up a recirc tank, purged and purged the system with the truck darn near on the tailgate - thought I had it licksd but no dice. Grounds should be more than fine - single ought welding cable for both engine and trans. I think it is still a bit of air. Upper and lower hoses are basically solid - not rubber that I can squeeze to help burp it. Think I’ll install the steam line kit for the rear of the heads as well and try to come up with some sort of expansion tank placed highest in the system. Crazy how the simple things aren’t so simple sometimes...
BMW & ASE Master Certified
Have you compared what the ecu temp via obd2 and digital Dakota is showing? Do you have the heater core lines on the water pump connected to anything?
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
Yes - the temp on both the ECM and DD are in line when the DD isn’t spiking. I have a loop on the heater lines now until the VA setup is finished. Not blocked but a loop hose.
![]() ![]() Join Date: May 2015
are you filling the engine thru the top radiator hose? and do you have the heater hoses where they can circulate?
