Old 09-30-2018, 01:58 AM   #1
mrjata
1960 w/crossmember swap, what headers?
Project is a 1960 c10. Just did the crossmemeber swap going to a 350/TH350. I can't get a good answer on what long tube headers I can use. I don't plan on slamming it, might lower it an inch or 2, that is it. Headman gave me a number but I don't have the torsion bars anymore. Not real fund of their tube placement.
I am open to ideas and pictures are a huge plus. Thanks all!!
mrjata is offline   Reply With Quote
Old 09-30-2018, 11:14 AM   #2
LVPhotos
LVPhotos's Avatar
Re: 1960 w/crossmember swap, what headers?
Since your not running a clutch the Hooker 2466 mids work. But long tube for ground clearace use fender exit and run down sides. Unless your pushing 500hp the diff is little if any.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 09-30-2018, 11:27 AM   #3
LVPhotos
LVPhotos's Avatar
Look in the faq section for other threads
Old 09-30-2018, 11:35 AM   #4
LVPhotos
LVPhotos's Avatar
Last 2 pic are another memebers. Pypes tunnel X
Old 09-30-2018, 01:21 PM   #5
mrjata
Oh, I have and made notes
Old 09-30-2018, 02:58 PM   #6
mrjata
ADMIN: Please delete this thread because I can't figure out how to do it. thanks
Old 09-30-2018, 11:34 PM   #7
Captainfab
60-66 Nut
Since you are wanting long tube headers and have eliminated the torsion bars, and are going with an auto trans, you can use any brand truck header for a '55-'87 truck.
Old 10-01-2018, 02:47 AM   #8
mrjata
Thanks for that very important info. I tried some from a 78 van and the pointed right at the x frame.
Thanks again!!
Old 10-01-2018, 11:14 AM   #9
LVPhotos
LVPhotos's Avatar
If you look at the pictures I posted, the 3/4s drop right at frame. So if your not running 500+ hp there is no reason to run the header any lower. If you must have long tube use fender well headers and run down side
Old 10-01-2018, 11:57 PM   #10
mrjata
Thanks again!!
Just came onto a new set for an 84pu, will fit fine might have to tweek but all is good, thanks Capt. Fab!!
Old 10-01-2018, 11:57 PM   #11
mrjata
Just tried a new set from a 84 pu, will work just fine. Thanks for the info!!
