06-03-2019, 03:03 PM | #1 |
Help with Part Identification
Hi,
Took apart the 68 last year and finally am ready to put it back together. I labeled each and every piece except for this one. I think it is an interior piece that has something top do with the steering column, any help in identifying where and how it goes is much appreciated, a picture would be even better! Many thanks, Larry |
06-03-2019, 03:06 PM | #2 |
Re: Help with Part Identification
Look under the steering column. The two rubber pieces are what the clutch and brake pedal rest against. Sorry I don’t have a picture.
Smitty '71 Short Fleetside Spring Valley, Ca. |
06-03-2019, 07:12 PM | #3 |
The Older Generation
It's called a pedal stop bracket/plate. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 06-03-2019 at 07:31 PM. |
06-03-2019, 08:47 PM | #4 |
ok, thanks, which end is up, or how does it fit? thanks, Larry
06-03-2019, 09:09 PM | #5 |
You can tell which side the bolt heads have tightened up against by the bare metal circles on the bracket. Put that side down and the rubber pads against the brake and clutch pedal arms. The bolts are 5/16 x 3/4 inch long. LockDoc
06-03-2019, 10:49 PM | #6 |
thank you Leon, you're the man
06-03-2019, 11:57 PM | #7 |
