Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 06-13-2020, 01:45 AM   #1
SoCalSlaughter
SoCalSlaughter's Avatar
89 S10 4.3 misfire
Hello all, recently my friend bought a 89 S10 with the 4.3 and 700r4 for $800. "Running" and driving. It has a decent misfire at idle, engine shakes abit. It has close to 180K miles. Engine starts fine, no ticking, no smoke out of the exhaust. Oil looks fine, cooling system is fine. No engine light. So far we have changed the O2, fuel filter, wires and plugs, coolant temp sensor, changed the dizzy (gear was worn and shaft had some play), replaced EGR valve, cap and rotor. Triple checked firing order. Base timing with with timing connector unplugged set at 0. When accelerating from a stop the mis is more present. Any ideas or direction would be appreciated! Thanks
1990 Chevy Suburban v2500
1990 Chevy/Geo Tracker LSi 4x4 2Dr
1996 Chevy/Geo Tracker LSI 4x4 4Dr
2011 Chevy Silverado Crew Cab LT
1991 Nissan 300zx SlickTop
SoCalSlaughter is offline   Reply With Quote
Old 06-15-2020, 06:46 PM   #2
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Re: 89 S10 4.3 misfire
Have you checked the coil? I had a pretty gnarly miss at idle on my truck and it turned out to be a bad coil.
-Automatics win races, 6-speeds impress high school kids
-Save a tree, support your local dragstrip.
-"Failure - The Secret To Success, the idea is that you can fail 100 times as long as you can succeed once" -Takeo Fukui
columbuscarsandcoffee.net and on Facebook
ProStreet68SB is offline   Reply With Quote
Old 06-15-2020, 06:50 PM   #3
Cali72K20
Cali72K20's Avatar
Try rebuilding the TBI, the diaphragm in the fuel regulator leaks on these and clean out the IAC orifices. It is really easy, the hardest part is getting the diaphragm screwed down while holding the spring.
Here is the kit: https://www.autozone.com/fuel-delive...82053_821751_0
YouTube: https://www.youtube.com/results?sear....3+tbi+rebuild
Cali72K20 is offline   Reply With Quote
Old 06-15-2020, 06:57 PM   #4
SoCalSlaughter
I've taken the throttle body off and checked, its not ripped. Haven't replaced the coil on the truck. Last night we did a compression test. Cylinder 2 and 6 have 120 psi. Cylinder 5 had 150. Cylinder 1 and 3 had about 135. I think the engine is toast.
Old 06-15-2020, 11:45 PM   #5
SoCalSlaughter
Took the MSD coil off my Suburban and tried it on the S10, no change.
Old 06-16-2020, 01:19 AM   #6
SoCalSlaughter
Compression readings
Cyl 1 - 130 - Wet 140
Cyl 2 - 135 - Wet 155
Cyl 3 - 120 - Wet 130
Cyl 4 - 150 - Wet 160
Cyl 5 - 140 - Wet 150
Cyl 6 - 125 - Wet 130
misfire, s10
