Old 08-01-2020, 08:38 PM   #1
studeclunker
studeclunker's Avatar
Rag Joint Replacement
Okay, yes I did a search and was left even more confusedl...
Took me a while of searching just to figure out what the silly thing is called.
My Rag Joint has disintegrated. I replaced the steering column and joint with one from a '65. Worked for a day and also came apart. Does anyone know where I can get one of these (new please)?
Application:
1966 Chevy C-20
Power steering
Power brakes
auto
350 (crate replacement)
studeclunker is offline   Reply With Quote
Old 08-01-2020, 08:43 PM   #2
franken
Re: Rag Joint Replacement
https://www.google.com/search?client...7-72+rag+joint
Old 08-01-2020, 08:58 PM   #3
studeclunker
Um... my truck is a '66. Weren't there changes to the column in '67? Some kind of slider?
Old 08-01-2020, 11:07 PM   #4
franken
Seriously? Maybe do a web search for your year truck.
Old 08-02-2020, 08:54 AM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
So the rag joint normally is attached to the steering box.
One end is splined? What diameter and how many splines are there on your box?
What diameter and configuration is the other (shaft) side? 3/4" Double D?
Old 08-02-2020, 05:54 PM   #6
studeclunker
I did. Thanks for the suggestion though. Almost all of the joints available are for '67-on. So, being a general ignoramus on this kind of thing, I started this thread hoping for some relief from confusion and frustration. Maybe someone who knows if a '67 joint will work would hopefully let me know. I have little enough to spend on this project and was rather hoping not to waste money on useless parts.
Old 08-02-2020, 06:54 PM   #7
The Rocknrod
Moderator
See post 5.
Old 08-08-2020, 02:53 PM   #8
Axle
Axle's Avatar
You can probably rebuild your exisiting rag joint using a newer one, just take them apart and reassemble using your original metal bits. Did that with my nova long before rag joints where readily available everywhere.
Axle is offline   Reply With Quote
Old 08-08-2020, 02:56 PM   #9
The Rocknrod
Moderator
Now there's an excellent idea. There are kits available on eBay as well. - http://67-72chevytrucks.com/vboard/s...d.php?t=614332
Old 08-08-2020, 09:17 PM   #10
Kudzupatch
Kudzupatch's Avatar
You can buy a rebuild kit.
Grind the heads off the existing rivets.
Replace the fiber disk.
Assemble with bolts and lock-nuts to replace the rivets.
Time consuming grinding off the old rivets but not hard and very cheap too.
Kudzupatch is offline   Reply With Quote
Old 08-09-2020, 03:19 AM   #11
mongocanfly
mongocanfly's Avatar
If you have a nearby napa or maybe other quality parts store, there are rebuild kits...you could take what's left of yours and see how close it matches....
https://www.napaonline.com/en/p/NDP6...iABEgI9BfD_BwE
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
