Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 12-20-2020, 06:28 PM   #1
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Brake line bender tricks
Inline brand 3/16 tube bender
Thought I would share some tricks that I couldn't find when searching...
You can bend vibration stress loops.. Basically you start off doing about a 45º rotate a little, 30º and so on till it naturally wants to coil around the handle. but about 30º is the most your going to bend at a time
While the small tube and a tight bend radius is way stiffer than wrapping/bending it around a 1.5 inch piece of pvc pipe or some can.
With the tube nut on, the closest you could make a bend 1.5" to the 0 mark
removed stock handle, found 2 3/8-24 nuts (probably from the 10 bolt rear axle backing plates) and welded them together, the bolt holding it to the die is smaller than 3/8, probably 5/16 which allow a little up and down to center the tube on the die.
basically shaves off .5 off the length between the tube nut and bend. all that's left to do is whip up a handle so I don't have to use a crescent wrench to hold the flats of the welded nuts / or a vice.
figured someone might find it useful, also doesn't damage the tool!
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 12-20-2020, 09:32 PM   #2
SeanB242
SeanB242's Avatar
Re: Brake line bender tricks
Nice work. Love seeing people come up with this kind of stuff
SeanB242 is offline   Reply With Quote
Old 12-21-2020, 12:37 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Great tip.
I think I’ll just build a handle with a hole in it for the tube nut.
Thanks for posting
Keith
Convert to disc brakes.
Old 12-21-2020, 06:28 PM   #4
A1971Blazer
A1971Blazer's Avatar
Good idea.......I Like it...thanks!
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
