Old 05-07-2021, 09:13 AM   #1
diveplane
Ok need oil lines
MY 1992 5.7 V8 i need new oil cooler lines
what ones do i need, i herd u need to l know about rear diff gearing first?
i checked my vin id says transmission short 4A/5M
transmission long 4-speed automatic
what do i need to get here?
autozone or oreilly
diveplane is offline   Reply With Quote
Old 05-07-2021, 09:37 AM   #2
EVRLET
EVRLET's Avatar
Re: Ok need oil lines
Does your glove box not have the RPO sticker?
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
Old 05-07-2021, 10:09 AM   #3
diveplane
yes i forgot about that , has G80 positraction limited slip,
cant quite make out the other letters here for ratios.
Old 05-07-2021, 10:16 AM   #4
diveplane
GU6 Axle Rear 3.42
Old 05-07-2021, 10:16 AM   #5
diveplane
used a magnifier glass lol
Old 05-07-2021, 10:37 AM   #6
diveplane
https://www.oreillyauto.com/detail/c...er+lines&pos=0
Old 05-07-2021, 10:45 AM   #7
diveplane
just ordered them woohoo.
Old 05-07-2021, 10:46 AM   #8
diveplane
thx i forgot about the RPO codes.
Old 05-09-2021, 03:29 PM   #9
Russell Ashley
Russell Ashley's Avatar
I don't know if your 92 is the same as my 96 K1500, but I recently changed the radiator in my truck with a 5.7 vortec, and changed the oil cooler hoses. I got mine from NAPA. They had a NAPA Gold label and I peeled it off and there was a Dorman label under the NAPA label. My longer hose was $31.99 and the shorter one was $21.99 for comparison. I would change the adapter that the hoses slide into while you are doing the job.
Russell Ashley is offline   Reply With Quote
Old 05-09-2021, 04:45 PM   #10
Just call me Sean
Just call me Sean's Avatar
I deleted my oil cooler. Even the new lines leaked at the crappy push connectors.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 05-09-2021, 10:38 PM   #11
Russell Ashley
I think it's pretty common to delete it. I was concerned about leaks too but so far it's working.
