08-06-2020, 01:06 PM | #1 |
Home Made Tools
Anyone got photos of those home made gadgets you made to get the job done? You know, the thing you need for that third hand or whatever to get a quick, non repetitive job done?
I had one the other night in the shop trying to press new lower ball joints into my lower A arms. They are off the truck and painted so I thought I would use my 12 ton press to install them. Problem was I didn't really have the right fixture to hold the A arm for the pressing. I only have two to do and it was about 10:00 p.m. so there wasn't any going to the parts store to borrow a ball joint press. A little thought, some left over lumber and here is my lower ball joint fixture. Piece of 4x4 with a hole cut in it for the ball joint stud and reinforced with more than just a few wraps of aluminum tape. Just wanted it to last for two pressings and it worked like a champ. What you guys got that could inspire the rest of us?
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra Last edited by 67C10Step; 08-06-2020 at 02:50 PM. |
08-06-2020, 02:46 PM | #2 |
Re: Home Made Tools
I needed a spindle nut socket for my front end, and when I went to O'Reilly the kid behind the counter looked at me like I had asked for a plasma fusion inductor. So I went home and made one:
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
08-06-2020, 02:59 PM | #3 |
Re: Home Made Tools
I needed this pulley on and didn't have the proper tool so...
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
08-06-2020, 03:17 PM | #4 |
Re: Home Made Tools
To many to count...usually if I need it I make it....
08-06-2020, 03:37 PM | #5 |
Re: Home Made Tools
I restored 3 old Cushman scooters and needed an engine stand so I could work on the engines.. I designed one and cut out the pieces.. My grandson was studying to become a welder so I gave him the pieces to weld up the stand..
08-06-2020, 04:31 PM | #6 |
Re: Home Made Tools
I have a plethora of homemade specialty tools that I have made
I suppose I cheat because I own a machine shop Here's one I used just last week to install a TrueTrac locker case spreader for GM 12 bolt truck
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
08-06-2020, 06:38 PM | #7 |
Re: Home Made Tools
That is pretty cool, I would never think you could stretch cast iron!
Greg
________________ 1970 GMC Sierra Grande, 2500 133" wb, 402, 4spd. 2007 GMC 3500 SRW 4x4, Crew cab, Duramax/Allison. (Sold} 1987 Chevy Suburban 2500, Silverado, 2wd, 454, t-400 2023 Chevy Silverado LT 3500, crew cab, longbox, 4x4 Z-71 Duramax. |
08-06-2020, 06:56 PM | #8 |
Re: Home Made Tools
Have lots of home made tools for cars . But I've been doing knives and hatchets for about 5 years . My hookaroon hand forged made the handle out of ash .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
08-06-2020, 08:40 PM | #9 |
Questionable
Re: Home Made Tools
There were a couple of these threads over in the Shop forum over the years. This is the one that sticks out in my head, but I swear there was another one in the 2006-2008 era also : http://67-72chevytrucks.com/vboard/s....php?p=5012999
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
08-09-2020, 10:52 AM | #10 |
Re: Home Made Tools
You know how we all save stuff. Had a broken breaker bar handle. Rusty Proto ball peen head with no handle. Put the two together, made one of my favorite little hammers. I use it for small roll pin installs quite a bit.
08-09-2020, 11:32 AM | #11 |
laying low
Re: Home Made Tools
I needed a NPT tap on a saturday late afternoon so I whipped this up from a 1/2” piece of pipe. Worked like a champ and have never needed it since. I cut 3 grooves in it with my grinder.
01-18-2021, 12:08 AM | #12 |
BMW & ASE Master Certified
Re: Home Made Tools
Plier bead crimping tool for small diameter tube. Making 5/8 and 3/4 heater core lines for another engine swap.
Works pretty nice, it leaves a nice smooth bead. Make one light pass, then full crimp the 2nd pass. If they started out as pliers vs crimper/cutters, I imagine it wouldn't make the marks on the tube.. Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
01-18-2021, 11:54 AM | #13 | |
Re: Home Made Tools
Oh yeah, you definitely can, but you shouldn't have to with a GM 12 bolt. That's Dana 60 kind of stuff.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
01-20-2021, 07:59 AM | #14 | |
Re: Home Made Tools
I have a few ratchets , that are dead. and hammers with cracked/junk handles. I'll have to cut/grind down the ratchets head, but , .. |
01-25-2021, 10:28 AM | #15 |
Re: Home Made Tools
Same here.
Not sure that this really applies, but I made it yesterday and thought of this thread, so what the heck... Using my metal band saw yesterday, I decided enough was enough. The flimsy sheetmetal cart that came with it required that I kneel on the floor every time I wanted use the thing, it was way “tippy”, it was a pain to move around, and it had next to no storage space. I took a break from working on the C10 and turned a bunch of scrap steel into a cart that’s actually usable. For a total investment of zero dollars and a couple of hours of my time, I’m quite happy with it. It's stable, easy to move, places the saw at a comfortable height, and has storage for metal scraps, blades, the table for vertical use, etc. I may make it pretty someday (clean it up and paint it), but I doubt it. |
01-27-2021, 08:06 PM | #16 |
Re: Home Made Tools
You guys will love this! A powered hacksaw for larger steel. An old man I know built it years ago and gave it to me about 2 years ago. The motor I believe is either an old belt drive blower or washing machine motor. The idler pulley is off an 80's Ford. The gearbox is from a commercial ice maker. The switch at the arm joint kills the power when the cut is finished. The bolt on the end of the arm is to hang a 5# weight off of. Just clamp your tubing in the vise, set the blade on it, hang the weight, start it up and walk away.
01-30-2021, 11:17 AM | #17 |
Re: Home Made Tools
Getting ready to pull the engine out of my 66 burb. Took an old cherry picker that I picked up on CL and adapted it to a 3 point hitch hook up on my tractor.
01-30-2021, 08:47 PM | #18 |
Re: Home Made Tools
Here is a tool I had made up from a friend of mine for taking dog dish hub caps off of deep dish rims. This prevents the painted rim from getting chipped edges. It works as the same principle as the old slid hammers. Hook on back edge of hub cap, and slid the collar back to break the hubcap loose.
03-09-2021, 03:37 PM | #19 | |
Re: Home Made Tools
The wrench is just made from 1/4 sheet and to fit into a specific place. I didn’t have an extra wrench to modify so cut this one out. Hardened it as best I could with a torch and some oil, been holding up so far.
1967 C10 LWB 250 6cyl 3ott Panaramic cab “Layla” 1967 Camaro 327 ‘glide cruiser “Bailey” |
03-09-2021, 06:37 PM | #20 |
Re: Home Made Tools
C-clamp and modified hole saw. Valve spring compressor
05-05-2021, 02:36 AM | #21 | |
Re: Home Made Tools
05-06-2021, 08:54 AM | #22 |
Re: Home Made Tools
05-06-2021, 11:40 AM | #23 |
Re: Home Made Tools
Just tried my modified Cherry Picker on my 66 burb engine swap. Worked great.
05-06-2021, 07:38 PM | #24 |
Re: Home Made Tools
