Old 06-07-2021, 04:41 PM   #1
car10107
car10107's Avatar
Any ideas to stop gas puking out when refilling?
Hello everyone, been dealing with this for a while and looking for ideas for when I will have the tank out soon. When I refill my 65 with the original behind the seat gas tank, gas will puke out when it gets full just as the pump stops. I know I have read where guys will just go really slow as it gets full and I have tried that too but still make a mess. This causes the cab to have a gas odor for the next day or two after refilling. I would love it if there is something I can do so that the pump shuts off when full but no fuel pukes out like on a newer car, any suggestions? I'm going to have the tank out here in the next couple weeks to replace the seat and install seat belts, trying to plan for some kind of mod when I have easy access to the fuel neck etc. Has anyone tried installing a baffle in the fuel neck that will allow the unleaded nozzle in with just enough room for clearance? Would this activate the shut off on the pump but not allow fuel back out? I just replaced the fuel tank so I have no plans to switch to an under bed tank. Thanks in advance.
1965 Chevy C10 283 SM420 Long Fleet "The Old Man"
1970 Chevy C10 350 SM465 Long Fleet "Dave"
1975 Toyota FJ40 "Mr Grinch"
1969 Pontiac Firebird
2001 Chevy Tahoe
2001 Toyota 4Runner
car10107 is offline   Reply With Quote
Old 06-07-2021, 06:39 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Any ideas to stop gas puking out when refilling?
The thread I link below is more about adding a return line, but it may give you some ideas. Basically you need something to let air escape as the tank fills up.
http://67-72chevytrucks.com/vboard/s...ghlight=Return
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-07-2021, 08:23 PM   #3
PGSigns
PGSigns's Avatar
Before I switched I always made sure the nozzle was all the way in and the pump was not running wide open as I filled it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
