"Tail Gate Best Seat In House"
![]() Join Date: Oct 2007
3.08 Rear end pulling a 22 ft. Travel Trailer
Question first of all ,are any of you pulling a trailer with a 305 chevy engine and a 3:08 rear end? How much weight are you pulling ?
Second Question ,,can you take the gears out of a 3:08 rear end and put 3:42 gears back in it ?
When you learn a thing a day you store up smart. |
Re: 3.08 Rear end pulling a 22 ft. Travel Trailer
Think you would be very underpowered and under geared. I tow an aluminum trailer with my 68 on it with my 72 350 and 4.11 rear . About 5k and I know it's back there . Had 3.08s in my burban 0to60 3 minutes
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
You'll probably want 3.73's to tow with a 305 especially if it is a smogger version.
How much the trailer weigh? Tire size or height? Which transmission do you have? I towed about 5,500 maybe 6000 pound box trailer with a 2.73 geared, and roller cammed 350 with about 325hp/425/tq. Built to roughly 95 Vortec specs, backed by a TH350 with a 2000rpm stall converter. The truck was not a fan of getting it moving, and the converter would flash to about 3000 as I started rolling. Once rolling it was not a big deal, but the start was a deal. At 55/60 I was at my stall speed so I often had to stay in 2nd to keep the converter "locked" up, but also for power as my rpm went from 2000 to 3000rpm roughly. So my friend who I was hauling the trailer for, and I. Just left stupid early in the morning to beat traffic, and only hit a bit once at the river. |
![]() Join Date: Mar 2003
Transmission and tire size factor into this.
Who Changed This?
![]() Join Date: Jan 2013
Look up the trailering specs for that truck. I'm pulling a 6000 pound trailer with a 400 BBC and a 3.54 axle, and it is seriously lacking on hills.
All about them K’s
![]() Join Date: Jun 2014
3:08+305+trailer=major dog in my opinion.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Nice truck but not for towing your camper.
Those tires look like 31x10.50x15's
I would go 3.55 and a posi-trac or locker
Its a Truck Thing......
3.42 will work on your 3.08 carrier.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
That truck would be a serious dog with that engine and gearing. No info on transmission? Seems like a newbie omission. If 700R4, dont bother. My dad has the same setup and truck. If a manual trans, not as terrible but still bad.
1982 K10 SWB 1987 V20 - Sold - Doh! |
![]() ![]() ![]() Join Date: Jan 2018
I towed a 20ft, all steel car trailer with a C20 frame and bed on it. Used my 63 with the 283, 3 speed overdrive with overdrive locked out (3rd gear, 1:1), 3.73s, and 29" tall tire. It pulled ok, but it showed me that I don't really want to be towing a complete truck with my combo. I definitely needed the 3.73s to pull that trailer. Maybe would have done better with 4.10s
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
That 86 should have a 700r4 and a 208 t-case. I'd go with at least a 4.10 or 4.56 with that tire size. A 4.10 in over drive equates out to a 2.87 final (4.10 x .7). With the 3.08 in overdrive you're pulling with a 2.1. I ran 4.56 in my older Suburban with a 700 pulling a 24ft travel trailer and it wasn't enough with 265-75r/16 (31s). That 'burb had a tbi 350. I was pulling it out of OD all the time to get anywhere on the hills around here. I just built (for a customer) an Explorer and he did the math with 35s and 5.13s. Runs great even with the V6
Play around with the numbers a bit on grimmjeeper.com. It's the best gear ratio calculator I've seen. Your cruising rpms at 60 mph should be above 2k for any power at all. 2500 would be good for a smaller engine like that.
A lot depends on how often you're pulling this trailer. If it's a one-time deal, just grin and bear it. If you plan to do it frequently, consider some serious upgrades. A larger engine and an overdrive transmission combined with a much shorter gear ratio should all be considered.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! Last edited by kipps; 10-07-2021 at 10:29 AM. |
#15 |
My 85 has a mild 350 basically built to pre smog specs with an RV cam ,2 inch exhaust ,upgraded 700r4 275/75r16 with 3.23 gears auxiliary trans cooler and I wouldn't pull a smal 2k trailer with it . 99% of the time I drive in D not OD on the highway OD doesn't work well with taller gears . Gas milage is pretty much the same
#16 |
I drove pops 84 K10 900 miles to deliver it. 350, 700R, 2.73 gears. Even empty, OD was useless, drive was OK at 70, and take off power was lousy. With a few thousand pounds, the tranny would die quickly.
#17 |
Are you saying that I can take the gears out of the 3:08 rear end and install 3:42 back in it ?
#18 |
Yes --the 10 bolt rears do not have a carrier breaks unless you start with a 2.56 gear
#19 |
For a 22' camper I'd highly recommend much more power, more gear, and more wheelbase, and honestly, probably more brakes, than that truck can provide.
Even when those trucks were new someone in your situation would have bought the 2500 longbed with a 454. Some things were "OK" 30-40 years ago when everyone else on the road had the same under powered vehicles and crappy brakes and for the most part, most people probably drove a little slower than now. Today you have family cars and SUV's with 250-400 HP that can hit 0-60 in 5 seconds, stop in half the distance from anything 30 years ago, and cruise at 90 mph. I guess if you're only going 30 minutes down the road to a local spot a few times a year it might get you by, but if you want to cruise the country... I wouldn't do it...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#20 | |
https://www.randysworldwide.com/shop/yg-gm12t-342 Smitty
#21 | ||
If this is an automatic trans truck, I would definitely do this. You will kill a 700r4 in short order.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#22 |
[QUOTE=GOPAPA
I have bought the truck I want ,,waiting to have it brought from Oregon to me here in Idaho,, now I can park it easier in town in them narrow short parking spaces .. Thx all of you ,,really appreciate the help with your input as it made me turn the truck down that I was thinking of getting ... I like this one much better ($18,000)and bought it from a private party and got lots of information from them. It has a 10 bolt rear end ,you can help me with what all comes in a 10 bolt rear end .. and,,,, let me know if I need to change the gears or not.. What's your opinion on it .. what you like or don't like ? Also ..I got some money left over so I can give some to Jason and Liz for them having this great truck site.. ![]() ![]()
#23 |
Another short bed? what is the gear ratio? manual 4 speed is better for towing but you may still have issues with the wheelbase and brakes. How heavy is the trailer and is that 22' from tongue to bumper or 22' plus the tongue?
#24 | |
[quote=GOPAPA;8981344]
Forgot to add nice truck
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 10-07-2021 at 08:38 PM. |
#25 |
That's a really neat truck, and I'm glad you're happy. That previous truck would struggle to push those tires let alone pull anything. And the weak point would have been the transmission if it was a 700 R4. The one you got with the manual should be stronger and you ought to be able to regear it do whatever you need. I would still be careful towing a 22 ft trailer with a short wheelbase truck.
