Old 08-20-2015, 04:04 PM   #1
Hart_Rod
Hart_Rod's Avatar
Lightbulb Bolt on hood brackets for Porterbuilt hood hinges.
HartRod Hood Brackets!
When I started getting ready to install my Porterbuilt dropmember hood hinges, I decided I didn't want to weld the provided hood brackets to my painted hood. I also looking for a way to have some side to side adjustment to allow for better alignment of the hood between the fenders if needed. So I spent some time trying to figure out a feasible way to accomplish this. After some trial and error, I finally came up with design that would bolt directly to the hood, requiring no welding. My brackets use the 2 factory hinge mounting points along with 4 - 3/8" nutserts installed in the hood brace. The Porterbuilt hood hinges attach directly to the mounted hood brackets. It's a very simple and clean installation. Let me know if you any specific questions or are interested in a set of the brackets. I'm offering the first batch at $200 shipped via USPS (CONUS only). Just paypal robhartley@aol.com and include "Hood Brackets" in the message.
Rob
P.S. Below is a great step by step thread written by boardmember Rockcrwln that shows you how to install your PBFab hood hinges. When you get to the step that shows you how to weld on the hood mount, you would continue you the installation process with with HartRod hood brackets!
http://67-72chevytrucks.com/vboard/s...+hinge+install
Hart_Rod is online now   Reply With Quote
Old 08-20-2015, 06:09 PM   #2
Gonepostal
Gonepostal's Avatar
Re: Bolt on hood brackets for Porterbuilt hood hinges.
Nice work
US Army Bomb Squad 83-96
There is no problem that a suitable amount of explosives cannot solve
Gonepostal is offline   Reply With Quote
Old 08-20-2015, 06:54 PM   #3
greystoke
did it change the cowl to hood alignment?
"Fear makes the wolf look bigger"
http://67-72chevytrucks.com/vboard/s...d.php?t=305629
greystoke is offline   Reply With Quote
Old 08-20-2015, 07:13 PM   #4
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Gonepostal View Post
Nice work
Thanks!
Absolutely not!!!
Old 08-20-2015, 08:02 PM   #5
Hart_Rod
Hart_Rod's Avatar
Here are some more pictures. I have a lot more on my Instagram, Hart_rod_chubtubz.
Old 08-21-2015, 03:17 AM   #6
andrewmp6
So you could run a fiberglass hood with these?
Old 08-21-2015, 06:18 AM   #7
Coursey
Coursey's Avatar
Nice! Keep coming out with innovative products!
Coursey is offline   Reply With Quote
Old 08-21-2015, 07:40 AM   #8
Hart_Rod
Hart_Rod's Avatar
Thanks Wesley!
I would think you would have no problem as these brackets helps spread the load over 12 points instead of 4 like the original. You would just have to make sure you secured the nutserts in the fiberglass. Let me know.
Old 08-21-2015, 11:29 AM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
I like the radiused corners and better flowing lines of the production version. Nice work!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-21-2015, 12:01 PM   #10
Hart_Rod
Hart_Rod's Avatar
Thanks Chris! I'm trying to make it something people will be proud to run on their trucks.
Old 08-21-2015, 01:27 PM   #11
gringoloco
A guy with a truck
gringoloco's Avatar
I'd be proud! Man, I sure hope this stuff is still around when I get back to the 'states and have a place to work on trucks again...
-Chris
Old 08-22-2015, 03:36 AM   #12
andrewmp6
I don't have one of these trucks but those could give people more options on hoods or help those who can't weld.
Old 08-28-2015, 02:28 PM   #13
Hart_Rod
Hart_Rod's Avatar
Thanks! Just let me know.
Thanks!
Old 09-14-2015, 09:19 PM   #14
Hart_Rod
Hart_Rod's Avatar
bump
Old 09-17-2015, 08:43 PM   #15
Longhornss
Hey this is a great idea. Your original post says you wanted a way to have some side to side adjustment. This is my concern with these hinges. But I am not seeing how you accomplish the side to side movement. I must be missing something.
Longhornss is offline   Reply With Quote
Old 09-18-2015, 08:13 AM   #16
Hart_Rod
Hart_Rod's Avatar
The mounting holes can be slotted to give you some side to side movement.
Old 10-14-2015, 09:07 AM   #17
Hart_Rod
Hart_Rod's Avatar
Installed pictures from a happy customer!
Old 10-14-2015, 12:14 PM   #18
Coursey
Coursey's Avatar
Any thoughts of doing this for other year models? 60-66? 73-87?
Old 10-14-2015, 12:28 PM   #19
Hart_Rod
Hart_Rod's Avatar
Not at the moment. I can't keep up with what I currently have going on.....
Old 10-30-2015, 11:04 AM   #20
Hart_Rod
Hart_Rod's Avatar
Bump!
Old 11-04-2015, 07:14 PM   #21
19SIKtySix
19SIKtySix's Avatar
I second this thought...poor 60-66 trucks are always forgotten. Keep us posted if you decide to make them available.
Chuck
Instagram: c_lo_garage
Check out my 1966 C10 project "El Viejito" here:
http://67-72chevytrucks.com/vboard/s...d.php?t=674614
19SIKtySix is offline   Reply With Quote
Old 11-05-2015, 11:37 AM   #22
Hart_Rod
Hart_Rod's Avatar
Will do!
Old 11-30-2015, 10:09 AM   #23
Hart_Rod
Hart_Rod's Avatar
bUMP!
Old 12-11-2015, 01:10 PM   #24
Hart_Rod
Hart_Rod's Avatar
bump!
Old 12-13-2015, 10:58 PM   #25
texastrendz
Can you give me a paypal. I want a set Of these.
texastrendz is offline   Reply With Quote
