Old 09-24-2021, 07:30 AM   #1
62K20
62K20's Avatar
62 4x4 Shock Help
I need some help. I need to replace the front and rear shocks on my 62 K20 and having a hard time finding any that fit. I'm hoping not to spend crazy money for them $600. Can any of you K20 guys out there let me know what you are using? Thanks
62K20 is offline   Reply With Quote
Old 09-24-2021, 08:01 AM   #2
JPBrecheisen
Re: 62 4x4 Shock Help
Try KYB KG5466
You'll need to swap out the rubber bushings. I used energy suspension hourglass ones and i believe rears need 3/4" parrt number 9.810G
Just pry the original bushings out with a large flat blade and pop new ones in
I did fronts same way except bushings are 5/8" and shocks are
KYB KG5417
I came up with these by measuring the original spirals at full extension and full compression and matched them from the KYB specs.
1960 GMC K1500 LB Fleet Side
1962 GMC K1000 LB Step Side
1988 Chevrolet C2500
Last edited by JPBrecheisen; 09-24-2021 at 08:04 AM. Reason: Additional information
JPBrecheisen is offline   Reply With Quote
Old 09-24-2021, 08:52 PM   #3
Joe P
Active Member
I just recently bought a pair of new old stock MONROE 66833 shocks for the my 66 K20 rear off e-bay for $50 including shipping. I came up with that shock after crossing part numbers. The eyes and bushings are the right size but I have not installed them yet as the rear axle is still out of my truck. I am running stock height on my K20 and still have those massive original spring blocks, so shock length is an important consideration. For the price I couldn't pass on the shocks. When I get them installed I will post with results.
Joe P is offline   Reply With Quote
Old 09-24-2021, 09:42 PM   #4
JPBrecheisen
Parts book pages front and rear shocks
Old 09-24-2021, 10:10 PM   #5
JPBrecheisen
Looking over the data on compressed and extended length, they're right on. I bet they fit just fine.
Monroe 66833
Compressed length 14.97"
Extended length 24.63"
Travel 9.66"
KYB KG5466
Compressed length 14.09"
Extended length 22.95"
Travel 8.86"
Old 10-11-2021, 10:14 PM   #6
albaz
Same shocks for 61 GMC k1000?
albaz is offline   Reply With Quote
Old 10-12-2021, 12:35 AM   #7
JPBrecheisen
I run those same KYB numbers on a 1962 K1000 and 1960 K1500, so they should be the same.
Old 10-12-2021, 12:35 PM   #8
albaz
Thanks for the help. Always seems like a challenge to get information on 60-62 GMC.
Old 09-24-2021, 11:40 PM   #9
62K20
62K20's Avatar
Thank you for the information very helpful. I Measured both shocks Collapsed and extended.
The Front Collapsed: 13.25", Extended:22", Travel Length:8.75"
The Rear Collapsed: 15.75", Extended:23.75", Travel Length:8"
Thank you for your help.
