10-22-2021, 07:22 AM | #1 |
1965 c10 sleeper
Has anyone built a sleeper 64-66 c10? I am thinking about a field fresh swb with skinny tires then a 454 under the hood.
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
10-22-2021, 09:25 AM | #2 |
Re: 1965 c10 sleeper
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
10-22-2021, 09:33 AM | #3 |
Moderator
Yep. That'd do it.
10-22-2021, 11:15 AM | #4 |
I kind of went that route, but I kept my original 283 engine. I gave it the usual goodies to wake it up including 416 heads from a 305 and focused on improving its street torque, I also added a Muncie 4 speed and kept the exhaust note very subdued. The interior looks like a hot rod while the exterior looks mostly stock. Some regard a 283 as weak, but mine is plenty enough for me and the 15 mpgs are pretty decent. It's a blast to bang it thru the gears at wide open too.
10-22-2021, 02:25 PM | #5 |
I am a big sleeper fan however the benchmark of 'fast' has been raised a lot in the last 10 years. It better be a pretty stout 454 to keep up in the day and age of ls turbos being swapped into everything under the sun.
1970 C10 l/b 292/4spd Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062 |
10-22-2021, 04:28 PM | #6 |
It's Better With Nitro
I went with 462 ci of Pontiac that made 528 bhp before 5K RPM and 500 ft-lb off idle on 87 octane.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
10-22-2021, 05:15 PM | #7 |
10-22-2021, 07:15 PM | #8 |
My truck has been a blast. Fun to drive hard, a pleasure to drive gently, and I drive it all over the place too.
If you want to know anything else about it just just ask. |
10-22-2021, 08:01 PM | #9 |
Go to youtube and type in 9000 rpm 283 launch and you can see how weak they are
