10-14-2021, 01:17 PM | #1 |
"Tail Gate Best Seat In House"
I am thinking of adding glue on strips
down the sides of my truck and I am curios about the these strips staying glued on and also if any of you have photos of your truck with glued on strips .
this is photos of my truck and of another pointing out about where I would add the glue on strip
When you learn a thing a day you store up smart. |
10-14-2021, 01:22 PM | #2 |
Re: I am thinking of adding glue on strips
I installed those on my red truck when I restored it in 2009.
They are still on there with no issues. A couple tricks: a) You have to clean the painted surface with a solvent that does not leave a residue (alcohol or laquer thinner) b) Don't touch the adhesive of the molding or the clean area of the paint with your fingers c) You have to push HARD. Really hard. Like in the assembly plant it would oil can the door hard. I used a small pie crust roller to go over the moldings and make sure they were completely wet out. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-14-2021, 02:38 PM | #3 | |
I will copy this and keep it ..
10-14-2021, 05:38 PM | #4 |
Mine were done from the PO, in the early 2000’s. I’ve had the truck going on 8 years, and they are still holding strong.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
10-15-2021, 09:51 AM | #5 | |
That' exactly what I want to do to mine,, but will wait until next summer when it is warmer ..by the way mine is being picked up today and will be in my garage on a day or so ..
10-15-2021, 10:30 AM | #6 | |
10-15-2021, 08:52 PM | #7 |
I looked at it ,, Wow! about as good as it gets .. amazing how some people can turn a truck into a gold mine to see and one worth a gold mine to own.. my 71 was a looker .but up close it had it's bad things ,, congrats on your truck TKCR
10-16-2021, 09:33 AM | #8 |
Thank you
10-16-2021, 12:05 PM | #9 | |
10-16-2021, 12:43 PM | #10 | |
If you buy a roll then you will have to buy a special cutting knife that cuts on an angle As for me I will buy the already cut pieces
10-16-2021, 07:43 PM | #11 | |
I got it from one of the usual suppliers: LMC or Classic or someone like that. K
10-19-2021, 01:13 PM | #12 |
I just wish someone made the High Sierra/ Scottsdale trim.
They made a "sort of" trim, but I got samples and nothing matches the OEM rear corners that are still on my truck. |
10-19-2021, 07:55 PM | #13 | |
I was wanting to buy the cut already trims for my truck but then noticed that the guy or so before me done away with the side gas tank door openers and put the tank under the rear ,, and so not more doors to use the small rails pieces ,, I would now have to buy a roll and the bevel cutter and do my own,,
When you learn a thing a day you store up smart. Last edited by GOPAPA; 10-19-2021 at 08:47 PM. |
10-21-2021, 05:49 AM | #14 |
I'm going to buy a roll and cut it on a chop saw. Cut it face down and go slow and it should come out great.
10-21-2021, 05:51 AM | #15 |
That's the textured black, with the chrome plastic strips top and bottom, right? I found that somebody made that 4 years ago or so, but I don't remember who it was. I need that stuff for my other truck, so if you find it, let us know.
10-21-2021, 08:45 AM | #16 |
What blade do you use :plywood blade"?
10-21-2021, 01:17 PM | #17 |
The problem I see with the glued on trim strips is that over time rust happens behind the strips. At least that is what happened to the originals.
10-21-2021, 01:36 PM | #18 | |
I started a thread about it back in the day. Still have trim corners and nothing else on my truck, but I've been focusing (on and off) on the interior lately. |
10-22-2021, 01:34 AM | #19 | |
The trim looks great but my K30 will not have trim after getting painted and the Jimmy will get it removed. They are not garage queens.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
10-22-2021, 07:21 AM | #20 | |
10-22-2021, 09:03 AM | #21 |
can you re-glue old strips that are falling or have fallen off ?
10-22-2021, 01:15 PM | #22 |
10-22-2021, 02:23 PM | #23 |
I used a utility knife with new blade to cut mine. Used a metal straight edge as a guide, no problem to do angles too.
I would recommend buying the roll of trim instead of precut. You will have plenty left over which is good if you need remove a crooked piece and/or redo a piece.
Larry 84 Chevy SWB, "Roy", dark blue orig paint, 6 cyl auto, PS, 88,000 miles. 72 Highlander LWB "Olive" med olive over lt yellow, air, 77,000 miles (sold) "It's a sorry man who can't find his wife a good job" |
10-22-2021, 03:23 PM | #24 | |
They make a special tool for cutting the beveled edges too.. maybe buy one maybe not ??
10-22-2021, 05:09 PM | #25 |
I dont think you need that tool to cut, trim is cut easily with sharp utility knife.
Check out this video by Kevin Tetz with LMC, it helped me a lot. https://www.youtube.com/watch?v=ffYSF-9dHdo&t=1001s This install is not that hard, dont be intimidated. Take your time on the first few pieces, you will do just fine.
