07-28-2013, 09:36 AM | #1 |
Automotive myths
I know we have all heard them.So lets discuss them and see if they are true.I will start with this one.A few years ago I was working on my 69 impala in my grandpas shop.I had my battery laying on the ground.Puffing away on his cigar my grandpa kept saying "You better pick up that damn battery before all the juice gets sucked out of it"Is this true?I have been told this several times.Whats in concrete to suck the juice out of a battery?
07-28-2013, 09:59 AM | #2 |
Re: Automotive myths
ground/// loads of people dont understand that concept
07-28-2013, 10:20 AM | #3 |
My battery out of my truck just sat on the concrete floor for 4 months...put it on the charger before putting it back in just to make sure I had plenty of juice to start the rebuilt engine.
Charger said it already had a full charge. Maybe the concrete has to be a certain thickness to drain your battery?
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives |
07-28-2013, 12:13 PM | #4 |
I think they have made changes to battery cases over the years. Used to be you didn't want to set them on concrete, but today's batteries don't seem to be affected by it as much. Seems odd that our corporate overlords would make something better...
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
08-22-2013, 01:31 AM | #5 |
#16876
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
08-22-2013, 01:57 PM | #6 | ||
Registered Cruiser
I intend to live forever. So far, so good. |
07-28-2013, 08:35 PM | #7 |
Anymore myths out there?
07-28-2013, 08:46 PM | #8 |
The concrete doesn't drain the battery. The dirt that collects on top of the battery allows the poles to connect and that's what drains the battery. The only issue with concrete and a battery would be if the battery leaked it will ruin the concrete.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
07-28-2013, 09:41 PM | #9 |
Watch out for your cornhole !
Ive heard the old yarn about concrete and batteries since I was a little kid. Fortunately my dad taught me to reason through things and make my own opinions.
If the concrete would make a circuit through the battery case and drain the charge, imagine the light show it would put on when you mounted it in a metal battery tray which really conducts electricity. Steel > concrete at conducting electricity. Posted via Mobile Device |
07-28-2013, 09:58 PM | #10 | |
yeah the batteries are sealed in a plastic case and dont seem to know or care where they sit...
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
07-28-2013, 10:19 PM | #11 | |
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
07-28-2013, 11:34 PM | #12 |
There was a problem with switching from synthetic back to regular oil 20+ years ago. At this point most oils are at least partially synthetic and considered a blend. There is NO issue switching back and forth with modern oils. In my opinion there isn't any reason to not run synthetic oil.
07-29-2013, 09:18 AM | #13 |
and a few others
11 Diesel myths busted:
http://www.dieselpowermag.com/featur..._myths_busted/
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
01-18-2014, 04:19 PM | #14 | |
'72 C10 Highlander | '69 GTO | '06 VFR800 | '96 XR250 |
07-28-2013, 09:41 PM | #15 |
How about not changing transmission fluid?Alot of people say they don't change it and have no problems.I own a 96 Mercedes.They have a problem of the reverse going out.There is a guy on the Mercedes forum who claims to have 330,000 on a trans that has never seen a fluid change and his still runs great.I know a man with 97 Toyota he bought it brand new never changed the trans fluid he has 250,000 no transmission problems.I also hear this on this forum.
07-28-2013, 09:55 PM | #16 |
hows about the ol black pepper in the radiator trick to stop a leak ??
07-28-2013, 10:10 PM | #17 |
Black pepper!I thought your suppose to crack an egg in it.
01-18-2014, 09:26 AM | #18 |
I have done the black pepper and the egg white Both work on small leaks
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
01-19-2014, 10:11 PM | #19 |
Old Duffer
In Nam we kept a couple boxes of black pepper in each of our trucks. The pepper wouldn't plug a gaping hole, but it worked great on the stray bullet hole.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
07-28-2013, 09:54 PM | #20 |
Oh yeah I should also add I have owned my tuck for over ten years only did one fluid change.It was just a fluid change didnt drop the pan and change the filter.Mine still shifts great.Knock on wood.
07-28-2013, 10:03 PM | #21 |
That you cant swap back and forth from synchtic to regular oil... cause u can if you let it drain long enough i have people at work that do it all the time though i dont recomend it
07-28-2013, 10:17 PM | #22 |
I don't know how true it is but I have heard that synthetic and reg oil are the same.The only difference synthetic has something added to it.Im no oil expert though.
07-29-2013, 09:41 AM | #23 |
The greatest automotive myth of all, and there's a lot of poor bastards out there that still believe it to this day...
Ford trucks > Chevy Trucks.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
07-29-2013, 12:39 PM | #24 |
Grandpa in the rustmobile...
Whatta bout puttin a penny on batt terminal to get rid of corrosion
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
07-29-2013, 12:57 PM | #25 |
i think the battery thing comes from the days of the old tar batteries, the plastic batteries wont do it.
"DON'T TOUCH THE TRIM!!"-Early Kyler |
