06-08-2022, 05:31 PM | #1 |
Question K10 Brake Rotors
Good afternoon fellow GM Enthusiasts
I have a question, hope my explanation is clear enough below. My local parts store ordered me new rotors for my K10 Project a few months back. When I went to put them on today they slide about 1/2 way in and the outer part of hub is hitting the cast inside rotor. It appears that the rotor inside cutout is about 1/4 too small? Am I missing something obvious? Could be the rotors were stamped wrong? Not sure but has me wondering. Anyone tell me the outside diameter of the hub? Mine is mounted and I don’t have big enough calipers to measure. Anyone have a part number for rotors that will work? The date stamps on axle housing and ring are late 1971 and it’s a Dana 44 front axle. Last edited by MDFarms; 06-08-2022 at 06:25 PM. Reason: Added more |
06-08-2022, 10:12 PM | #2 |
Re: Question
Humptey bumptey
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
06-08-2022, 10:19 PM | #3 |
Re: Question
The rotors go on the inside of the hubs and the studs go through them into the hubs
06-09-2022, 02:48 AM | #4 |
Re: Question
On a K10 the hub is cast into the rotor. Most new rotors should have races for bearings already installed. Should only have to install the seal after rear bearing is installed. If rotor is hitting the knuckle/spindle something is not right. Did you install the bearing and seal on back side of rotor?
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 06-09-2022 at 03:17 AM. |
06-09-2022, 08:35 AM | #5 |
Re: Question
This is for my 85 yours should look similar the hub and rotor are serviced as one piece
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
06-09-2022, 09:16 AM | #6 |
Re: Question
I guess most all of my trucks have been K20's. Is that whole assy really cast as one piece? I know they tried to sell me the whole thing last year when I rebuilt my D44, but the rotor did come off by pressing out the studs.
__________________ '68 K10 496/465/205 |
06-09-2022, 12:24 PM | #7 |
Re: Question
The rotor pictured in post #5 is from a K20 (8 lug) Attached a pic of the rotor on the axle I removed from my 72 K10. The Rotors were the same on my 85 K10. Always sold as one piece afaik.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
06-09-2022, 01:28 PM | #8 |
Re: Question
Ah, okay. Post #5 is what I have, except for I have the external hubs. Those come off pretty easy and I think they were the same rotors I used for the 14b rear axle disc brake conversion.
06-09-2022, 04:24 PM | #9 |
Re: Question
I just posted as I had it save . For reference as the rotor and hub are usually serviced as one unit wether it’s a 10 or 20
06-09-2022, 05:06 PM | #10 |
Re: Question
I constantly get rotors separate all the time either 6 or 8 lug. Knock the studs out slide the rotor off and reverse the procedure. Not at all uncommon. As far as your fitment issue I would make sure the rotors match the ones that came off. May have gotten a wrong or mis-machined part
06-11-2022, 04:30 AM | #11 | |
Re: Question
