Old 02-25-2012, 03:42 PM   #1
lolife99
67-72 parts collector,…
lolife99's Avatar
67-72 Bench Seat Bracket Differences
Just thought I would add a few pics of the differences in the 67-72 bench seat brackets.
They are divided by the following years:
67-68
69-70
71-72
The "floor side" of the brackets are all the same.
It's the "seat side" that is different.
I will post the pictures I have,... but I really need good clear pictures of a set of 67-68 and 69-70 seat brackets, if anyone has them.
I would like to make a FAQ on this subject.
Many people don't realize these are year specific, and don't interchange.
Please post pics of what you have,...
Keith
Convert to disc brakes.
Old 02-25-2012, 03:50 PM   #2
lolife99
lolife99's Avatar
Re: 67-72 Bench Seat Bracket Differences
67-68
These are the 67-68 version.
(they are upside down from normal installation)
I have circled the main difference.
The "sheetmetal" rear seat riser.
The other difference is the adjustment arm is just a stamped metal arm.
The 69-70 and 71-72 arms have a black plastic coating on the arm, besides the plastic knob.
Keith
Old 02-25-2012, 03:53 PM   #3
lolife99
lolife99's Avatar
69-70
The 69-70 version have a tall "straight" rear seat riser.
These only work with the 69-70 seat frames.
(the 71-72 seat frame is different)
Does anyone know if these will work with the 67-68 seats?
Keith
Old 02-25-2012, 03:54 PM   #4
lolife99
lolife99's Avatar
71-72
The 71-72 seat brackets have a lower "curved" rear seat riser.
These work only with the 71-72 lower seat frames.
Keith
Old 02-25-2012, 03:56 PM   #5
VA72C10
VA72C10
VA72C10's Avatar
Thanks, definitely FAQ worthy!
Old 02-25-2012, 04:00 PM   #6
lolife99
lolife99's Avatar
Hey VA,... if you have any pics of the bucket seat mounts,... post them here, please.
Maybe the difference between the 67-72 and 73-75(?) mounts.
I have this "67-72 vs 73-75 bucket seat bracket info" from the other thread:
You "could" swap the front stands (floor mount) and use them, but they'd still be 5/8" inch taller at the front and 1/2" taller at the rear...
The bucket seat brackets are the same at the bottom rear for 69-72 and 73-up.
It's the front stands on the bottom and BOTH upper stands that are different.
The front stands on the bottom (cab floor side) are a full inch taller on the 73-up brackets.
The pieces that bolt to the seats are the same bolt pattern but different heights also. The front seat mount stand is 3 1/4" high on the 69-72 bucket mounts and 3 7/8" on the 73-up
The rear seat mount stand is 2 7/8" high on 69-72 bucket mounts and 3 3/8" on the 73-up
Keith
Old 02-25-2012, 04:09 PM   #7
shawno72
C/10 junkie
shawno72's Avatar
Again something I didn't know.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 02-25-2012, 04:46 PM   #8
VA72C10
VA72C10
VA72C10's Avatar
Will do. I'll take pictures later this evening or tomorrow and note the measurements on the pictures to make it easier to understand.
Old 02-25-2012, 05:02 PM   #9
chiefcfd
chiefcfd's Avatar
I thought the differences were for the full foam and spring seat bottoms. Didn't realize it was year specific.
chiefcfd is offline   Reply With Quote
Old 02-25-2012, 06:21 PM   #10
CSGAS
optomistic ah-so
CSGAS's Avatar
If I'm reading that correctly, it sounds like later buckets can be bolted to the correct bucket brackets for our year of truck and installed with no drilling. If that's true, then I also hope the same is true for benches.
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 02-25-2012, 07:51 PM   #11
VA72C10
VA72C10
VA72C10's Avatar
Yes, later bucket seats can be bolted on to the correct brackets with no drilling. 73-75 buckets almost look identical to 71-72 foam...the top foam is slightly different but the bottom foam is identical...
Not aware of any benches that bolt onto the stock bench brackets other than the benches designated for that year bracket...
Old 02-25-2012, 08:11 PM   #12
VA72C10
VA72C10
VA72C10's Avatar
Here are the mounts...I will post better close up pictures tonight with measurements added but this should help people identify the brackets if they see them for sale or on a set of seats.
Old 02-25-2012, 09:48 PM   #13
68gmsee
Active Member
68gmsee's Avatar
I agree. Someone may be doing a year correct restoration and could use this info. I wasn't aware of the differences either.
68gmsee is offline   Reply With Quote
Old 02-25-2012, 09:53 PM   #14
lolife99
lolife99's Avatar
This isn't neccessarily for "correct restorations".
It matters for any 67-72 truck when replacing the seat brackets.
They physically don't interchange unless paired up to the correct seat.
I see them for sale all the time in the classifieds,... and no one specifies which year they are for.
Just 67-72.
I found out when I bought the incorrect set for my '69.
Keith
Old 03-05-2012, 05:19 PM   #15
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
good thread Keith
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 03-05-2012, 09:21 PM   #16
lolife99
lolife99's Avatar
Does anyone have a good clear picture of the 67-68 bench seat mounts?
Also a BIG thanks to VA72C10 for the excellent bucket seat pics!
We may have to add "Utility Buckets" to this thread,... if anyone has good pics.
Keith
Old 03-06-2012, 12:35 AM   #17
kcsa75
kcsa75's Avatar
subscribed
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 05-11-2012, 02:29 AM   #18
VA72C10
VA72C10
VA72C10's Avatar
ttt for people who might need this and to remind myself to get some measurements...also will take some better side pics...
Old 05-11-2012, 09:10 AM   #19
gcburdic
Restoration Virgin!
gcburdic's Avatar
good thread Keith!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 05-11-2012, 09:46 AM   #20
fastcam1
Young gun
fastcam1's Avatar
I have a good one but it seems I can't post it from my phone, if you want I can email it to you
67 SWB Custom "JANE"
http://67-72chevytrucks.com/vboard/s...d.php?t=554024
Northwest C10's
http://www.facebook.com/#!/groups/Norhtwestc10s/
Cameron sparks
fastcam1 is offline   Reply With Quote
Old 05-11-2012, 09:55 AM   #21
67c10rustbuket
67c10rustbuket's Avatar
I can snap pics of mine (1967) just let me know what to look at and what to take pics of. My brackets are still on the seat which is setting in the cab not installed so I can remove it easily.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 05-11-2012, 10:08 AM   #22
lolife99
lolife99's Avatar
I'll PM you my email address.
Keith
Old 05-11-2012, 10:09 AM   #23
lolife99
lolife99's Avatar
I just need clear upright pics of the 67-68 seat brackets from the side and front.
Prefer off the truck seat.
Keith
Old 05-11-2012, 12:18 PM   #24
lolife99
lolife99's Avatar
Thanks to member fastcam1,... here's a better picture of the 67-68 seat brackets.
I circled the rear seat riser that is a stamped sheetmetal bracket.
(different than the 69-70 or 71-72 brackets)
Keith
Old 05-11-2012, 01:36 PM   #25
67c10rustbuket
I see fastcam beat me to it, I'm at work for a couple more hrs. Thanks for posting the differences Keith. There are so many little differences on these trucks that most people don't know about, including me. I learned a lot of them so far and many the hard way.
Dan <---(my name)
