12-06-2020, 05:42 PM | #1 |
64 C10 5.3L/4l60e
Anyone who has done an LS/4l60e swap into a 60s C10.
Did the 4L60E look about the same position as mine in the Mine came with a manual transmission originally. I already cut out the transmission cross member to put in my dirty dingo cross member but it looks like the emergency brake cross member is the one that really needs to come out.... I would like to keep an emergency brake if possible so I'll have to look into how to replace the crossmember or move it back and shorten the cables going to the drums and lengthen the one going to the brake handle. Guessing since the trans is sitting right on top of the E brake cdossmember thats where my new one needs to go.
1964 C10 Resto-mod 5.3L - L59 |
12-06-2020, 06:34 PM | #2 |
Re: 64 C10 5.3L/4l60e
I think I may have found one issue I have my motor mounts mounted in the frame holes closest to the cab and I think they need to be in the forward holes and see where it sits.
Will try that tomorrow before I remove cross member.
12-06-2020, 10:44 PM | #3 |
60-66 Nut
The best solution to the e-brake crossmember interference is to convert to the '66-'72 cables. That eliminates that crossmember. Some people have moved the e-brake ceossmember to under the frame.
12-06-2020, 11:27 PM | #4 |
Was hoping to keep cross member, just bought new cables for the rear. Will see about flipping it to under the frame and see what clearance I have. Will do some research and see if my new cables can be used on the newer style setup and maybe price out all new as well if its a headache doing flipped member
12-07-2020, 12:30 AM | #5 |
Guess if I have to swap everything over I am looking at $175ish with everything from lmc. Assuming I can continue i6sing stock handle for the 64.
1964 C10 Resto-mod 5.3L - L59 Last edited by Justin71105; 12-07-2020 at 12:38 AM. |
12-07-2020, 06:14 PM | #6 |
Handles should be the same through '68. I believe '69 is when the foot pedal came into play.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-07-2020 at 10:32 PM. |
12-07-2020, 08:44 PM | #7 |
Handle does look like I can reuse it, here is the list I have from LMC for all the parts I think I would need. Think I will go this route over trying to put the cross-member under the frame and such.
34-3836 – REAR BRAKE CABLE 2 REQ 34-3113 – PARK BRAKE CABLE GUIDE KIT 34-3820 – FRONT BRAKE CABLE 34-1251 – REAR BRAKE CABLE BRACKET 2 REQ 34-3131 – INTERMEDIATE CABLE BUSHING SET 34-3121 – PARKING BRAKE CABLE CLIP 34-3123 – PARKING BRAKE CABLE DUST BOOT 34-3805 – EQUALIZER-INTR BRAKE CABLE 34-3125 – PARK BRAKE CABLE GROMMET 34-3828 – INTERMEDIATE BRAKE CABLE 34-1251 – Brake Cable Brkt-w/Hardware
1964 C10 Resto-mod 5.3L - L59 Last edited by Justin71105; 12-07-2020 at 08:59 PM. |
12-09-2020, 09:31 PM | #8 |
E-brake crossmember out and trans crossmember in. Motor bolted down and ready to get a drive shaft for it.
12-18-2020, 11:06 AM | #9 |
I see you kept the engine in the rear mount holes on the frame. What adapter plates are you using?
12-21-2020, 06:54 PM | #10 |
ICT branded ones, using rear holes but with engine in most fwd position on adapters. Sits it perfectly for the DD trans crossmember to bolt in stock e brack crossmember spot and tailhoising to sit right in place.
12-21-2020, 07:00 PM | #11 |
Got the fuel lines ran just need to pull a little more slack up the firewall. Got the trim in for where I cut the inner fender for the power steering and it fits very well.
01-08-2021, 09:44 PM | #12 |
Getting ready to put the order in to have my drive shaft built and have been looking at drive line angles before I even have it. It will be a one piece driveshaft, my truck did not come with a drive shaft when I bought it.
Trans is currently 4.3 degrees down "slopes downward from front to back" when measuring off of trans seal or crank pulley. Pinion also slope "down" 1.8 degrees, slopes "down from front of truck to rear. Rom eye balling it the driveshaft will also slop "down" fromt to rear, an unknown amount until I get one. Would a 6 degree shim in rear to get the pinion to slope up "front to rear" 4.2 degrees be the way to get these opposite and "almost" equal. Running 4.5" drop in front and 5" drop with coils in rear. Very confusing with the up/down....to me the trans visually is down from front of engine to trans tail. Looking at pinion I "think" up b/c the pinion faces up towards front of engine. Using the drive line calculator on spicers website and using 4.3 down for trans and 4.2 up for pinion (shims) I cannot get operating angles within the 3 degrees with any driveshaft angle. However having all the angles slope down on their calc I get my needed angles with a 0-5 degree drive shaft angle. Making very little sense even after looking at the forum posts, watching the video explaining it in posts ect.
1964 C10 Resto-mod 5.3L - L59 Last edited by Justin71105; 01-08-2021 at 10:28 PM. |
01-09-2021, 01:30 AM | #13 |
I'm assuming your on trailing arm rear suspension....so the lower you go the more the pinion will rotate down..can you shim the trans angle to 3deg and run a 4or5deg wedge in the rear?...without the driveshaft its gonna be difficult to figure your working angles..
In a perfect world you want the crank centerline to be parallel to the pinion centerline... But sometimes, it seems this just doesnt work for some people's rigs when really low..
01-09-2021, 03:54 AM | #14 | |
01-09-2021, 07:39 AM | #15 |
Not get 3 degrees out of trans without cutting trans tunel out and reworking. May be able to get 4 degrees, have half an inch maybe a little more between trans and tunnel right now.
Do not mind flipping the trailing arm brackets to help with pinion angle or running shims. But from the spicer calc running a 4 degree down trans - "X" degree down driveshaft - "X" degree up pinion I cannot get working angles where they need to be no matter what driveshaft angle is. However with all 3 angles sloping "down" front to rear I get the needed operating angles with a good range of driveshaft angles. I know I dont yet have a number for driveshaft angle but using any number with pinion sloping up gives me an operating angle wayyy over 3 degrees.
01-09-2021, 11:02 AM | #16 |
Thanks Scoti...I dont fool much with trailing arms and havnt seen those brackets...those are nice..
Justin...dont quote me here and Scoti maybe can clear the air.. I watched the Spicer video about 3 times..if I understand what hes saying, when he says diff down, hes talking about the angle from front to rear as viewed from the side..,the centerline of the pinion shaft,, so on their calc you would want 4deg down, which means the diff nose needs to be up 4.2degs.. At 2:40 he talks about angle up and down being viewed from the side... https://m.youtube.com/watch?v=TUFzehQBDPI So when I say pinion up I'm referring to the nose of the pinion pointing up, which in turn is the way Spicer describes it as being down...some confusion there for sure..
01-09-2021, 11:05 AM | #17 |
So if all your angles are down your working angles will be 2,2..as you showed above...so either the brackets Scoti showed or wedges should work..
if it were mine ,I would cut the floor, do a tunnel, and set the trans and diff angle at 3 deg..(personal choice)...that would get the working angle down to around 1deg.. I understand you not wanting to do a tunnel though, and what you have should work
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 01-09-2021 at 11:21 AM. |
01-09-2021, 11:27 AM | #18 |
This is what mine would look like from side with a deiveshaft. but that pretty much completely contradicts what I read online that your front and rear should be opposite angles of one another
Lol. I've probably looked through two or 300 pages of driveline posts and watched videos on it I still dont understand it. I'm going to ask the driveline shop Monday when I order my driveshaft how it should be.
01-09-2021, 11:37 AM | #19 |
This is what yours should look like
You want the centerline of the trans to be parallel to the centerline of the diff
01-09-2021, 12:44 PM | #20 | |
If thats the case I can use 2° shims in rear pivoting pinuon further backward for 3.8° and raise trans to 4° Then the operating angles will all depend on driveshaft but I will be within 1° for yoke/pinion and should also be for operating angles as well, just hope they are less than 3°. Which it should be as long as driveshaft is between 2-6°
1964 C10 Resto-mod 5.3L - L59 Last edited by Justin71105; 01-09-2021 at 01:06 PM. |
01-09-2021, 01:04 PM | #21 |
That's weird. I've never heard pinion angle described by which way the BACK of the rear end points. Trans points down, front of rear end points up. Both should be at or near the same degrees. The way Mongo describes it is the way I always think with two imaginary lines running parallel to each other. These angles are best measured with the wheels on the ground and all the weight on the vehicle.
01-09-2021, 01:54 PM | #22 | |
Many websites say the angles need to be the same value +/- 0.5 degrees while also being opposite....one - and one +. Thays where my brain started wandering.
01-09-2021, 05:04 PM | #23 |
Yeah..the way he describes the angle up/down on the video is confusing compared to how we normally describe the angles.....
But I always try to set the trans and pinions at the same numerical number but opposite angles (+..-) And like stated this needs done with all the weight on the suspension .. A 2deg shim will get you close..and these angles change some with suspension movement as you drive anyway Still theres some folks here that set theirs up perfect, just like show on paper, but the results dont work for them..so it's hard to analyze how some setups are when you cant lay eyes on it
01-09-2021, 06:42 PM | #24 |
On my 68 C10 LS 4L60E SWB my engine is at 3.5 degrees. 6" rear drop. I didn't check the angle of the rear end. Had the drive shaft made and I have zero vibrations. I would shim the trans so you have an 1/8" between it and the tunnel. The other thing to watch out for is clearance between the the drive shaft and the trailing arm cross member. If you could some how lower the engine via the engine mounts that would help a lot.
01-20-2021, 01:09 PM | #25 |
Got my drive shaft in, transmission raised as much as I can and shims in rear end.
I come out with 3.9 in rear 3.9 on engine/trans but only .85 on the driveshaft. Guess I will have to cut the trans tunnel and either try raising trans even more. Or find a way to raise motor itself on the mounts or frame brackets. Thinking some poly bushings may be stiffer than the rubber and raise it some but maybe not enough to get me downward angle on the drive shaft.
1964 C10 Resto-mod 5.3L - L59 Last edited by Justin71105; 01-20-2021 at 01:25 PM. |
