06-28-2021, 10:55 AM | #1 |
205 VSS Solution
I installed this on my K5 swap. I know in the past this company was a little sketchy on delivery, but new owners seem to be on top of things. This installs easy and gives you the correct 40 pulse for your swap without losing your original speedometer. Delete if innapropriate.
https://behemothdrivetrain.com/produ...TPeRnLLQY1KUSE |
06-28-2021, 10:59 AM | #2 |
Re: 205 VSS Solution
Ok, so clue me in. Does this take place of part of the transfer case? Just bolt on, or is there more to it? Not a 4x4 guy, but may be doing a swap for a buddy in the near future.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
06-28-2021, 11:05 AM | #3 |
06-28-2021, 11:21 AM | #4 |
Replaces the rear seal plate on back of the 205 Transfer case. Toughest part is removing nut on yoke. Will post picture tonight.
06-28-2021, 01:52 PM | #5 |
That looks great I was looking at speedo splitter and use 1 to run vss generator other to run speedo
If I was to use 4l80e I would add second reluctant ring in build |
06-29-2021, 09:49 AM | #6 |
Picture of Transfer Case with VSS installed
06-29-2021, 08:57 PM | #7 |
I’ll have to remember this when the poor design advance adapter 4l60e to np205 adapter with the tone wheel clamped on the transmission output shaft fails.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
07-01-2021, 11:30 AM | #8 |
Does it take a standard gm vss pickup ?
07-01-2021, 01:53 PM | #9 |
Yes, Standard VSS and Plug
