Old 05-07-2023, 10:59 AM   #1
LDO
LDO's Avatar
Quadrajet Connector
I have a quadrajet carb on my 85 Silverado. It has the plug for the dual capacity accelerator pump on it. It is a yellow-ish/brown plug with the two wires going to it. The only wires on the carb. As you can see in the pic, the wiring harness side of the connector has a broken locking tab so I would like to replace the connector.
Does anyone know where to find this or a suitable substitute for it?
Thank you.
LDO is offline   Reply With Quote
Old 05-07-2023, 03:08 PM   #2
Bandit130
Bandit130's Avatar
Re: Quadrajet Connector
Maybe one of these links will help. There are probably other places too. You will need the number of your carb.
https://quadrajetparts.com/
https://quadrajetpower.com/new-quadr...oaAkTNEALw_wcB
https://www.carburetion.com/quadrajet.asp
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is online now   Reply With Quote
Old 05-10-2023, 08:15 PM   #3
LDO
LDO's Avatar
So far, nothing. Tried all the quadrajet specific websites, Napa, etc.
If anyone has this connector zip tied out of the way because you have swapped carbs, let me know.
Old 05-10-2023, 09:10 PM   #4
dmjlambert
dmjlambert's Avatar
Can you pull the connector off and show us a picture of it?
Old 05-10-2023, 09:28 PM   #5
ray_mcavoy
Ditto what dmjlambert said ... a picture of the connector with it unplugged from the carb would be helpful.
I'm thinking it might be a Delphi / Aptiv Metri-Pack connector. Possibly something along the lines of a #12052644 https://www.customconnectorkits.com/12052644/ but can't say for sure.
ray_mcavoy is offline   Reply With Quote
Old 05-11-2023, 07:30 AM   #6
LDO
LDO's Avatar
Yes, sorry about that. I will pop off the air-cleaner and get some pics of it tonight.
Old 05-11-2023, 10:47 AM   #7
THI
Active Member
THI's Avatar
If that solenoid is not connected, then the accelerator pump act normal when you step on the accelerator. If it is working normal, once the engine reached 170* it will be activated and when you step on the accelerator half of the fuel from the accelerator pump will be circulated back into the float bowl and the other half down the throat of the carb. This setup was only on Light Duty Emission trucks for 1985 and 1986.
THI is offline   Reply With Quote
Old 05-11-2023, 06:45 PM   #8
dmjlambert
dmjlambert's Avatar
That is interesting. I wonder if it saves a noticeable amount of gas.
Old 05-12-2023, 10:15 AM   #9
406 Q-ship
406 Q-ship's Avatar
If you are talking about the 2 wire plug on the top right side carburetor that is the connector for the mixture control solenoid does not anything to do with accelerator pump. It was common for that plug to break off the locking tap, at the dealerships we would just run two zip ties between the wires and around the whole connector. The only connector that has anything to do with the accelerator pump is the 3 wire connector on the left side front of the carburetor, it is the Throttle Position Sensor and has nothing to do with the operation of the pump at all.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 05-12-2023, 10:40 AM   #10
LDO
LDO's Avatar
Cool, can you explain to me how it works and what it does? While the busted clip is annoying to my OCD, I would rather know something new about my truck. Everywhere I've looked, to include here, it has been referred to as the dual capacity accelerator pump.
Also, if you have any insight as to where I can find a new connector, that'd be great!
Thank you.
Old 05-12-2023, 12:25 PM   #11
geezer#99
geezer#99's Avatar
It’s a mcs!
Mixture control solenoid.
Info here.
https://www.carburetor-blog.com/know...nic-quadrajet/
Old 05-12-2023, 07:39 PM   #12
dmjlambert
dmjlambert's Avatar
Dual capacity accelerator pump control or Computer controlled mixture control solenoid in that position on Quadrajet, depending on the innards and application. Here is how to identify: https://www.crankshaftcoalition.com/...celerator_pump
It may be possible to find a connector if you can you pull the connector off and show us a picture of it. Perhaps a picture of the connector on the wire, and the connector on the Quadrajet.
