01-27-2020, 01:08 AM | #1 |
Distributor block off plate for a 292
I need to plug the hole where my distributor used to go. Does anyone know of anybody that makes one for a 292? All I can find is V8's. Thanks.
01-27-2020, 02:07 PM | #2 |
Re: Distributor block off plate for a 292
I am assuming that you aren't using an oil pump driven by the cam that has to be driven by the distributor shaft?
You are probably going to end up having a local job shop machine shop turn one out of a piece of round stock unless you have access to a lathe or a buddy with a lathe. It's a simple basic lathe job if they have the distributor to measure from. There are so few guys doing the setup you are that there is no market for producing a plug. On the other hand you might get by with the right size cup plug.
01-27-2020, 10:26 PM | #3 | |
01-28-2020, 01:06 AM | #4 |
Now I need to go look at my distributor to make sure of what the hold down looks like but you may want a raised center about the height of the thickness of the hold down clamp on the top side.
01-28-2020, 09:18 AM | #5 |
01-29-2020, 11:11 PM | #6 | |
http://home.metrocast.net/%7Eshannen/yota/ you can see the homemade distributor plug here: Eventually you realize that everything good is a one-off. |
01-29-2020, 11:41 PM | #7 | |
