Old 07-28-2022, 09:40 AM   #1
JayE72
Unhappy Short and to the point
Truck caught on fire. Slowly rebuilding. I was told that I need a carburetor throttle kit or something from Jeg's or Summit Racing. Can someone tell me the part number and the exact name of the part I need?
Thank you in advance.
J
JayE72 is offline   Reply With Quote
Old 07-28-2022, 10:22 AM   #2
68 P.O.S.
Re: Short and to the point
This? https://www.summitracing.com/parts/atp-y103
Sorry to hear about the fire.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 07-28-2022, 10:41 AM   #3
LNP
Sorry to hear about the fire. I hope no one was hurt and the truck wasnt damaged to bad. Do you need a transmission detent cable as I see the end of one in your photo? But it looks like a carburetor throttle shaft in your hand.
They do make seals for some carbs for that. If its a detent cable what trans do you have?
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 07-28-2022, 01:26 PM   #4
JayE72
No it is the one that goes on the carburetor. I went from Q-Jet to an Edelbrock. The replacement throttle doesn't fit on the throttle lever peg (no sure about the exact name). The truck is a 72 Cheyenne short bed. 350/350. The passing gear never worked.
Old 07-28-2022, 01:56 PM   #5
72SB
OP
This is the carb stud I put on my Edekbrock to mate with my accelerator linkage on my 67 Camaro. Sold at the usual places, Summit, etc
I think its this one but it says for trans...
https://www.jegs.com/i/Edelbrock/350/8018/10002/-1#
Also might want to put in a fire extinguisher in case....
72SB is offline   Reply With Quote
Old 07-28-2022, 02:26 PM   #6
geezer#99
geezer#99's Avatar
And a question for the op.
Have you had it running since the fire?
Old 07-28-2022, 02:35 PM   #7
72SB
Originally Posted by geezer#99 View Post
It is for a transmission 72SB. Not the one he needs.
Op said he put in a Edelbrock carb...I just showed him the trans stud I used for the kickdown cable I see in his pic
Assuming the ball stud in his pic no longer fits in the slot end of his cable
There is a variety of ball and slot studs that may work. Some may require slight enlarging of the hole in carb lever
My accelerator rod fitting worked on my Eddy. Not seeing what OP has but my pic shows how both accelerator and Kickdown are attached to the Eddy carb
OP
Google Edelbrock carb throttle stud and see what comes up for your application.
Old 07-28-2022, 02:45 PM   #8
geezer#99
geezer#99's Avatar
What ball?
Old 07-28-2022, 04:53 PM   #9
LNP
Look here.
https://quadrajetparts.com/throttle-...ead-p-412.html
Ok I am confused. Does he need a carb stud for a throttle or detent cable?? The stud 72sb posted is for a detent cable. The one you posted is for a snap on throttle cable. Maybe the op will chime in and clear up the confusion.
Harley
Old 07-28-2022, 05:02 PM   #10
geezer#99
geezer#99's Avatar
Process of elimination.
Old 07-28-2022, 06:00 PM   #11
LNP
His detent cable never worked, he doesn’t want or need it so it’s the ball stud I linked he needs.
Confusement reigns when a poster comes back and edits his post like 72LB did.
Ok, I dont see where he said he never used the detent cable he did state passing gear never worked. To me that can be from improper adjustment, using the wrong bracket, and a couple other reasons. Being a 350 turbo it will shift ok
without a cable but will not kickdown for passing. Which ever stud for the carb he needs you two have him covered. Wish he would have given more info and better photos. Oh well we do what we can.
Harley
Old 07-29-2022, 10:30 AM   #12
72SB
...? well Geezer, edits are typical when one reads a post after and wants to clarify intended response.
Your response for a carb the OP said he didn't have was "confusing"
JayE72
Old 07-29-2022, 11:23 AM   #13
geezer#99
geezer#99's Avatar
You better read this quick, I might edit it.
Too late.
Delete delete delete.
Old 07-29-2022, 12:05 PM   #14
LNP
LOL Looks like someone did a clean up in isle five.
Harley
Old 07-30-2022, 07:09 AM   #15
Are we still helping JayE72 here?
Old 07-30-2022, 08:46 AM   #16
72SB
Tried in post #5...hard to see in his pic (blurry) the part on his throttle rod end. I assume that is what he needs to connect to his Edelbrock carb. My pic shows what my linkage does. Not sure if the ball stud in his pic talks to the kickdown lever or if thats even on a Eddy carb...which is why I also posted that stud
OP has not come back but here is link to various Eddy adapter linkage parts. Maybe the 9141 is what he needs??
https://www.summitracing.com/search/...on%3Aedelbrock
Old 07-30-2022, 11:50 AM   #17
LNP
I did as well also asked him a couple questions to see if I can help further. He hasnt been on since the day he started this thread.
Harley
Old 07-30-2022, 12:07 PM   #18
Grumpy old man
Grumpy old man's Avatar
J
The part that is missing in this repair is , 01 MECHANIC
Post more pictures of the part you need ? That engine is looking a little crispy ?
